Deutz Diesel GeneratorI posted before here about this unit thats made by stevenson for the military is a 5KW only 120...this thread has 6 replies and has been viewed 1646 times
I posted before here about this unit thats made by stevenson for the military is a 5KW only 120 volts, it would not produce because the exciter winding was burn and had rewind and put it together and hit the fields with 12 volt and got juice, now i going to put it on a frame job instead of the military sound prof enclousuer, i need if anybody nows where to get a manual for now enjoy the pictures this 5KW CTMGSA Duezt Diesel is the model type
The Following User Says Thank You to panzerwillie:
Wow. I had a chance to bid on a pair of these, but passed because I couldn't tell if they were 3600 or 1800 rpm. The rotor on that machine looks like its a 2-pole machine. Do these really run at 3600 rpm?
good to hear from you jim it is 3600 rpm and its good solid unit i will remove a lot of the complex things with the engine, the only thing that i can't
figuere out its that it had a rectifier i belive coming out of the wires from the generator , there is 2 think L-1 and L-2 AND THEN THE 2 FIELD WIRES PLUS 4 MORE THAT HOOK UP TO THE RECTIFER AND TO THE VOLTAGE REGULATOR I WILL BE NOT USING THE VOLTAGE REGULATOR THAT CAME WITH ANY THOUGTHS
Are you speaking of the wire on the engine opposite the generator end? If so this is the alternator to chare the battery. 24 volt I assume. Older 5 and 10 k military genset I have worked on have a "Brick" which is the rectifiers and voltage regulator for charging the starting battery. Input should be two wire from the stator with about 40 volt AC output when the engine is running at 3600 rpm. If you do not have the regulator you might try Saturn Surplus.
Kent |
If you are refering to the wires coming out of the generator head, yes i believe it had something to do with the charging system, for the batterys, how ever it does have a build in alternator in the front of the engine which is conected to a regulator and the power side of the starter
Is that As the bestos
I see wrapped around that zaust pipe?
SOOO MANY TOYS,SOOO LITTLE TIME,SOOO LITTLE $$$ TO BUY ONLY SO MANY OF THESE OLD BOY'S TOYS!!! |
no is a espesial heading pad to keep the heat in the pipe while in the sound proof covers it had
| Deutz hopper cooled Diesel | Steve Sorensen | Vintage Diesel Engines | 6 | 03-21-2008 06:29 PM |
| 1 CYL Deutz Diesel | Dail R H | Vintage Diesel Engines | 3 | 09-17-2007 05:12 AM |
| Generator, MEP 701A, 3KW, Diesel | Rb Hawaii | Military MEP and Aircraft Gen-Sets | 2 | 01-05-2004 11:02 PM |
| deutz diesel | LYNN BAIN | Antique Engine Archives | 0 | 12-27-2002 10:27 PM |
| diesel-generator | bruceTadlock | Antique Engine Archives | 0 | 11-08-2002 09:22 AM |
