| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
IHC LB Head removalHi, This is the first LB engine I have had a chance to play with. I'm trying to understand the...this thread has 1 replies and has been viewed 590 times
Hi, This is the first LB engine I have had a chance to play with. I'm trying to understand the process for removing the head. It appears that the valve rockers must be removed in order to get to the upper two bolts of the 4 bolts that hold the head on...I don't have any wrenches that will fit back there with the rocker assembly on. How do the rockers come off???? There is a screw with a broken-off head in the left hand side of the rod that holds the rocker arms ( sort of visible in the picture attached ), I assume this has to come out to remove the valve rockers? I know this is a super-common engine, so someone in this group must know !
OK I just saw the other threads in the archives on how this is supposed to come off. Sorry for the bandwidth !
| IHC LB engine head removal | Gerry Magnan | Antique Gas Engine Discussion | 4 | 10-30-2007 11:56 PM |
| Name/SN tag removal | Greg Shipley | Antique Gas Engine Discussion | 5 | 11-07-2006 11:35 AM |
| Ihc LB head removal | Jas L | Antique Gas Engine Discussion | 3 | 05-21-2006 01:24 AM |
| 1.5 HP LB govenor linkage removal from crankcase to head ?? | Dale | Antique Gas Engine Discussion | 1 | 03-30-2005 07:25 PM |
| Head Removal Le Roi Upright | Bruce Wambach | Antique Engine Archives | 0 | 08-06-2003 07:57 AM |
