Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Letz Grinder Serial Number Registry
this thread has 21 replies and has been viewed 7960 times
Old 04-26-2008, 11:32:14 AM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Letz Grinder Serial Number Registry
Hey guys.
Since there are no surviving records of date/serial number information anywhere (not even at the JD archives), I thought I might take it upon myself to try and start compiling serial numbers for Letz feed grinders. The difficult part will be to keep all the different models sorted out as I think there were at least 15-20 different models. If you would like your number added to the registry, just post the serial number and model number in this thread or email me. Pictures would be nice as well. If you have ANY history at all that might help to narrow down a purchase date, that would be immensly helpful as well. Thanks!
Jeb
Old 04-26-2008, 11:34:27 AM
JKWidener's Avatar
JKWidener JKWidener is offline
Images: 26
Default Re: Letz Grinder Serial Number Registry
If the tag is gone, where would you look to find your serial number?
Never assume the obvious is true. -William Safire-
Old 04-26-2008, 12:00:04 PM
Jebaroni's Avatar
I'm not sure that there was another location for the s/n other than the tag. You might try looking on the end of the shaft nearest the drive pulley but I doubt it would be there. I don't know of any other stampings on the frame but then again, I only have one model. Other models may have been double stamped but I do not know this for fact.
Jeb
Old 04-27-2008, 08:25:26 AM
midpw midpw is offline
Good Job Jeb,
I'll to get over to the pole barn today and get you a model and serial number from mine.
Bruce
Old 04-27-2008, 06:59:46 PM
Jebaroni's Avatar
Ok, through the good folks over at www.gristmillers.com, certain pages from the 1947 "Book of Repairs" have been scanned in. Apparently, this booklet also contains serial number range data for several models of grinders as well as year ranges through which they were produced. Currently this only covers the following models: 130, 140, 230, 230x, 240, 330, 340, 360, 370, 344, 430, and 540. Only roughage mills are covered and only models of grinder produced through 1946 even if they continued production of that model afterwards. If you have one of these models, I can give you a reasonably close estimate of the year of manufacture. I'm still hoping to get serial number data for the more common 80, 110, 220 and similar grinders and will keep you all posted.
Jeb
Old 04-27-2008, 07:53:50 PM
FarmSC's Avatar
FarmSC FarmSC is offline
Default ok, what brand is this?
I forgot I even owned this. On the crank handle is stamped"NO. 2" and each casting is noted with a '2M' number...such as '2MA' '2MB", etc.
Also, note the half-moon shaped shims laying in front of the mill...what are these for? This mill was disassembled when I got it from my father. He picked it up somewhere and took it apart to clean, then when he passed, I inherited it.
Anyway, what have I got here?
Thanks,
Kevin
Old 04-27-2008, 07:59:21 PM
Jebaroni's Avatar
Well, to me it looks a lot like the C.S. Bell No. 2 grinders that they are still selling today. As for the shims, I have no clue. Try taking it apart and see if you can find any others inside the mill? That or try contacting C.S. Bell directly and see what they say?
http://www.csbellco.com/grinding.htm
Jeb
The Following User Says Thank You to Jebaroni For This Post:
Old 04-27-2008, 08:04:19 PM
Handlebar99 Handlebar99 is offline
Are you sure those "shims" go with the mill? They certainly look like Half moon clips for 45ACP ammunition.
Ray Rice
The Following User Says Thank You to Handlebar99 For This Post:
Old 04-27-2008, 08:05:40 PM
FarmSC's Avatar
Knowing my father, that's entirely likely. Now that I look at them from a different light, I can see that.
Kevin
Old 04-27-2008, 08:10:45 PM
Jebaroni's Avatar
Hopefully, he was not getting ready to "take the mill out back and shoot it"....
Old 04-27-2008, 08:54:18 PM
Jebaroni's Avatar
If you felt like sandblasting it down to bare metal, you could very closely examine the castings for an imprint. I have a hand cranked corn sheller that I did not know the manufacture of. After sandblasting, I found the imprint of a small bell that (if I remember correctly) had a CS inside of it. That made it a sinch that it was a CS Bell corn sheller. If you were to sandblast your unit and look closely, you might find a similar impression. The one on my sheller was so light and faint as to be nearly unnoticable. It certainly disappeared under even the thinnest layer of paint.
Jeb
Old 04-29-2008, 07:38:27 PM
Jebaroni's Avatar
There wouldn't happen to be anybody out there with the Letz 1947 "Book of Repairs" or really this book from any other year (not sure how many were made)? I would really like to get my hands on one of these. Thanks.
Old 05-05-2008, 06:53:17 PM
Jebaroni's Avatar
Well, i'm at 98% done with refurbishing the Letz elevator that I got with my model 80. I still have to finish the diverter paddle that goes in the discharge spout, make a metal cap for the bottom of the elevator, nail on a metal trim piece, and make a 12" long bolt to hold the legs on. I plan on leaving the elevator as it is, unpainted. I have coated it with Valspar Polyurethane to protect it from the elements and by leaving it unpainted it will match the unrestored grinder a lot better. Also, by leaving it "anonymous", I might be able to use it with one of my other grinders like the large David Bradley shown in the compilation picture. Anyway, just thought you guys might like to see a restored elevator. We have a small tractor shown around the end of this month and I should have some pictures of the elevator and the mill belted up to each other then so stay tuned!
http://s293.photobucket.com/albums/mm59/jebaroni2/Letz/
Jeb
Old 05-07-2008, 12:49:17 PM
Pitalplace's Avatar
Pitalplace Pitalplace is offline
I just saved a Letz 220 serial # 605858 from the iron dealer. I have no idea of the year of manufacture or any other information. I will get pictures and post when I get a chance. I would like a copy of any manuals if anyone has any.
Old 05-07-2008, 06:10:22 PM
Jebaroni's Avatar
All I can tell you is that they began production in 1926 and continued at least through 1946. I do not know what the beginning serial number was or how many total units were produced. It seems that every series that Letz made started with a different serial number range and there doesn't seem to be any patterns behind it either. I still don't understand why the 1947 book of repairs gives serial number data breakdowns for the roughage grinders, but not the hopper grinders (the 220 is considered a hopper grinder). Oh well! At least you have a beginning date. If it were me, i'd take the average and call it a "1930's vintage" rather than trying to assign a specific year.
Jeb
Old 05-13-2012, 08:43:11 PM
Alan Bowen Alan Bowen is offline
I own the 1947 book of repairs and a later supplement but there is no way they will be for sale in my lifetime.
If I run into them soon I will let you know.
---------- Post added at 08:43 PM ---------- Previous post was at 08:20 PM ----------
My number 8 Letz was made in 1914 and soon was replaced with one with a larger main shaft.
http://www.oldengine.org/members/bow.../Letzpage.html
My model 8 is missing it's flywheel because at the Haswell farm when they were done with it they removed the flywheel and added it to another feed grinder that they later sold Letz flywheel and all. I did get several extra sets of burrs with my number 8.
I have what looks to be a model 80 flywheel but it has the hole for that larger shaft. I will have to bush it down until it fits the number 8.
My number 80 Letz is in rough shape and I need to make a new hopper for it.
Right now I am seeking transportation help to get a model 6 from PA to the Portland show in August. That one is in really great shape and will be a welcome addition.
The Following User Says Thank You to Alan Bowen For This Post:
Old 07-31-2012, 09:36:45 AM
fordson1 fordson1 is offline
Hey Jebaroni, heres a quick vid of a couple of Letz Burr mills I recently finished, thanks to all of the information I've garnered from various posts on SmokStak.
The larger Letz 80 A, # 836799 was a bit more of a challenge requiring two others for spare parts. The little 6 A Junior, # 22141 was in quite good shape, good babbitt, just needing cleaned up and lubricated and painted. They were a fun project!
http://www.youtube.com/watch?v=BB67s...ature=youtu.be
The Following 3 Users Say Thank You to fordson1 For This Post:
Old 07-31-2012, 11:59:33 AM
Jebaroni's Avatar
Very cool! That little Number 6 is just as cute as a bug's ear! Very nice job on both! I'd love to restore mine like that someday, but right now it's my good "dirty" machine that I don't mind using. Perhaps I can relegate my David Bradley to that task in the future. Again, nice work and thanks for sharing!
Jeb
Old 08-06-2012, 06:22:44 PM
Mike Rock Mike Rock is offline
Nice! Did you make the stencils for the lettering? I sure like the patent date part, well done.
Most respectfully,
Mike Rock
Old 09-17-2012, 12:03:11 PM
Mike,
The vinyl decals are available from Jorde's. They specialize in John Deere decals but do others and do custom work. A great business to deal with.
http://jordedecals.com/
The Following User Says Thank You to fordson1 For This Post:
Letz feed grinder JKWidener Farm + Industrial Antiques and Collectibles 2 06-11-2007 12:50:56 PM
Associated serial number????? Gene Fisher Antique Gas Engine Discussion 2 06-05-2007 08:23:48 PM
Letz Grinder Questions midpw Farm + Industrial Antiques and Collectibles 10 05-30-2007 12:28:13 PM
Letz corn grinder Kent T Antique Gas Engine Discussion 1 08-13-2005 10:33:48 AM
United serial number registry Dick Webber Antique Engine Archives 1 06-22-2004 09:44:49 AM
