Onan Paint - correct color ready to go
this thread has 26 replies and has been viewed 10979 times
Old 05-06-2008, 05:33:34 AM
lokay5 lokay5 is offline
Arrow Onan Paint - correct color ready to go
Have anyone found a readily available paint that's a match for Onan's green ?
Thanks!
Old 05-06-2008, 06:00:38 AM
Gunny Gunny is offline
Default Re: Onan paint
Onan sells touchup paint in rattle cans. They are excessively proud of it but if you need just a little, that's the way to go. If you need more, as in enough to paint the whole machine, take a chip to NAPA and they'll mix a batch for you.
The Following User Says Thank You to Gunny For This Post:
Old 05-06-2008, 06:36:03 PM
Skytruck's Avatar
Skytruck Skytruck is offline
Default Re: Onan paint - correct color ready to go
If you have a NAPA paint store they have the color in their database and can use different base formulas.
http://www.martinsenour-autopaint.co...%202359&f1id=1
The Following User Says Thank You to Skytruck For This Post:
Old 06-29-2009, 12:19:54 AM
ASavage ASavage is offline
Just had my copy of the ES Parts Catalog out (928-0222 (Spec A-G)), and found this:
Onan Green Enamel
(Non-Metallic)
525-0305 12 oz Pressurized Spray Can ($19 (!) @ M-n-D)
525-0306 Quart Can
525-0304 Gallon Can
Old 06-29-2009, 05:07:18 PM
JamesB JamesB is offline
If you are talking the current light blue-green NAPA sells it. Their paint code is 53A13235. It is real close to being a match.
Old 06-29-2009, 06:54:14 PM
Onan Green Enamel
(Non-Metallic)
525-0306 Quart Can
525-0304 Gallon Can
Like I said last year.................
Old 06-29-2009, 07:58:35 PM
airbatica airbatica is offline
Anyone happen to know the paint code (or an equivalent color match) for the cream color used on the older marine gensets?
Old 06-29-2009, 09:06:51 PM
RSlifkin RSlifkin is offline
Airbatica - I always thought the marine sets were just white. Apparently my MCCK isn't as dirty / oily as I thought then.
Old 06-29-2009, 10:38:53 PM
Maybe they are, and the paint on mine is just so old it looks cream-colored.
Old 06-30-2009, 09:23:08 AM
What year is your genset? Mine looks kind of cream colored at this point as well. Maybe I'll try cleaning part of the unit to see what it looks like.
Old 09-02-2009, 10:37:34 PM
Richard L Richard L is offline
I had a new 15 djc I acquired a few years and took a part from it and went to Roda paint here in Seattle and they a perfect match,and it is a quick dry machinery enamel.
Thier # is 206-547-7405,and there is a black fellow working the counter, name is Nathan i think.
Any way ask for him and he can look up the mix under RP&L Inc, and you can use it in a hand held Wagner sprayer, and you cut it withZylene. They will ship.Suggest you play around and find the right mix,its easy if it globs add a little more thinner,
Would send you some pics, but headed to Winipeg.
Re
Rick
I have 3 military sets,and 2 cck to paint and am using that.
Old 02-20-2010, 08:57:20 PM
krc002 krc002 is offline
Hello all, does anyone know when the Onan switched from the metallic green paint to the plain Onan green? i went and saw an older Onan EK or 45KW unit or some larger unit than my 12.5RJC and the green was metalic looking. im looking to see what year the switch was made for when i repaint mine. i believe the 45kw unit was a 1969 unit that had been stored inside so the paint was still nice. mine is from 1972 and looks like its been outside all its life and am curious as to which paint to use.
Old 02-21-2010, 12:00:58 PM
Billy J Shafer's Avatar
I think switched around 1971.
Old 02-21-2010, 12:25:26 PM
well that would explain the color difference. good to know. Thanks!
Old 02-21-2010, 06:34:16 PM
71PAHighboy 71PAHighboy is offline
Maybe I am being dense, but was one of the above entries for the Metallic Green?
I checked the Napa link, but it did not specify.
Thanks!
Old 12-30-2010, 03:40:31 PM
Default Re: Onan paint - correct color ready to go - Metallic Green
All,
Since I disassembled my 30EK I took some of the original parts into a paint shop and had them mix and match the color. On the original metallic green parts the color is a great match.
The paint is PPG Shop Line (JE) Prophet Fromula.
Brand Code 47214 main layer
Here are the mixing specs for 1 QT:
Blue Shade Green - 298.4
Trans Yellow Oxide - 64.3
Drier - 18.2
Tinting White - 14.7
Gold Mica - 2.2
White Mica - 17.6
Med. Blue - 13.3
Med Brt Alum - 110.1
Clear - 501.4
You should be able to take the above info and get a matching paint for an original shade. This will not account for sun / oil fading, so be aware that it may be off if you try to match existing paint.
Good Luck!
The Following User Says Thank You to 71PAHighboy For This Post:
Old 01-01-2011, 04:51:45 PM
Darxen Darxen is offline
SEARS has it !! Look up SEARSPARTS.COM and type in part number 525-0305, the Onan part number...I think it is $12.75 per spray can, plus shipping...I think if you order it at a sears part store,,there is no shipping charge if you pick it up.
Happy New year
Old 01-01-2011, 11:19:04 PM
Happy New year
Uhhh...
First, there is no searparts.com, it is searspartsdirect.com
Second, as started in the earlier portion of this thread, that is the non-metallic paint.
Finally, good job in finding a better price....
Old 11-20-2014, 07:20:14 PM
A911Pro A911Pro is offline
SearsPartsDirect.com $40.35 Paint-grn 13. How things go up in a few years.... I believe they have added some gold to it!
Old 11-20-2014, 08:23:49 PM
len k len k is offline
Back in the 70's even on cars ~ 8 years old the paint can be sun faded, and required a "custom" mix to match the paint. Can buff thru the white surface haze to get to the better color below, but it still can be faded. Most Onans here are a "little" older than that.
On older faded cars we would order the factory mix color then adjust the color to match the car. We shot paint on so many cars back in the day that we had lots of paint left over from other cars. But if you wanted to match a peice , just bring in a buffed peice to the car paint store and they can add a little extra tint to match it. Our store will mix paint for you on the spot.
Lauson Correct Paint Color? Kelly Reynolds Small Air Cooled Gasoline Engines 4 11-15-2010 10:18:23 AM
Sparta 4HP Model CX, Need Correct Paint Color Henry Macomber Antique Gas Engine Discussion 0 10-29-2010 07:51:27 AM
AHH Correct paint color. OldironPhil Small Air Cooled Gasoline Engines 4 05-16-2010 09:23:03 PM
Color of Onan paint hitnmiss Onan Generators 4 02-16-2009 02:29:43 PM
Correct paint color for United 2HP Tim Dean Antique Gas Engine Discussion 3 10-29-2007 06:34:46 AM
