Go Back   SmokStak > SmokStak® General Discussion > Alternative Fuels
Alternative Fuels
Joe cell?
research that.....does it really work? or' "stan meyer " let's get this stuff going let's get it...
this thread has 7 replies and has been viewed 1597 times
Old 05-07-2008, 12:04 AM
Clark Bigger Clark Bigger is offline
Default Joe cell?
let's get it out in the open
The Following User Says Thank You to Clark Bigger:
Old 05-07-2008, 09:11 AM
KeithW's Avatar
KeithW KeithW is offline
Default Re: joe cell?
When you start looking into any "break water into H and O2 to burn in the engine as you drive" setups also check out perpetual motion machines. Unfortunately it takes more energy to break apart water than you get from burning it. So, you're taking an inefficent internal combustion engine, running an inefficent alternator, running an inefficent chemical reactor and expecting to gain energy? Sad but true, TANFL.
keithw
The Following 3 Users Say Thank You to KeithW:
Old 05-08-2008, 12:30 AM
Benjamin Roth's Avatar
Benjamin Roth Benjamin Roth is offline
From what I have read about the Joe Cell....it's nonsense. That design does make a very good electrolzser though.
If it takes more fuel to run the alternator to power the electrolyzer.....why do you still see a 3 mpg increase in fuel economy?
Benjamin
The Following User Says Thank You to Benjamin Roth:
Old 05-08-2008, 10:57 AM
KeithW's Avatar
"If it takes more fuel to run the alternator to power the electrolyzer.....why do you still see a 3 mpg increase in fuel economy? "
The normal reason, poor control of the test conditions. There is a reason for large samples, double blind tests, and all that fun stuff.
It is also possible that the efficiency of the engine is being increased by something other than what they think is causing it. If that is the case then the same results could be produced by implementing the real cause and dumping the hocus-pocus.
It's like all the magic spark plugs. Any new plug will work better than an old worn out plug. You never see them take two cars and put new OEM plugs in one and the magic plugs in the other.
keithw
Old 05-11-2008, 02:35 AM
your right.....sorry to take up space....moderaters, you can delete this thread clark
Old 05-11-2008, 12:30 PM
KeithW's Avatar
I vote for not deleting. It was a good question. With all the hype and snake oil going around it's good to have at least a little sanity out here in the big cyber world.
keithw
Old 07-24-2008, 09:24 PM
Simon Thomson's Avatar
Simon Thomson Simon Thomson is offline
Location: Kilwinning, North Ayrshire, Scotland, United Kingdom
Default Re: Joe cell?
I believe there is a way to make this work. It's just a case of building testing improving starting over etc etc. Been following electrolyser and water power sites for a good while now but there's a helluva bull***t out there and quite a lot of nastiness. One site which was very good got so bad so quickly that I no longer visit it.
Nearly everybody seems to be concentrating on straight DC at very low voltages because hydrogen is generated at one pole and O2 at the other because they learned it in science at school and are blinkered to other methods. There are a few interesting developments at high voltage high frequency ac say 4-8kv at say 10-20khz (plasma generation voltages). The parts to build generators capable of these voltages are available for pennies at the likes of radio shack but very few seem interested. I reckon it will happen one of these days hopefully sooner rather than later.
Simon.
Old 07-24-2008, 11:56 PM
someone needs to complete the idea! you're wasting all that CO2!! if burning hydrocarbons makes H2O and CO2, why not build a car that burns both CO2 and H2O!!!
Some people just hate to believe basic science, you simply can not get more energy out of water then you put into it. NEVER. mankind will never do it, short of a nuclear reaction (even then, you are simply decomposing the water further down...)
Robert
Label for old dry cell battery Eric McKenna Antique Gas Engine Discussion 7 03-22-2008 10:59 AM
#)*()^#%*#$@# Cell Phones! Craig A Smoke, Flames & Gas (Off Topic) 22 02-01-2008 07:20 AM
Gell cell charger John Drabik Antique Gas Engine Discussion 14 10-02-2007 01:49 AM
Dry Cell Battery's Ed Kuni Antique Engine Archives 10 03-18-2003 08:30 PM
jell cell batterys Doug Wilson Antique Engine Archives 18 09-05-2002 08:22 AM
