MEP003A Parts NumbersHi to all my name is Mark and this is my first post to the forum. The reason for my post today is...this thread has 14 replies and has been viewed 1498 times
Hi to all my name is Mark and this is my first post to the forum. The reason for my post today is in the preparation of having one of my gensets a MEP003A delivered to my location but with the knowing anticipation that the blower (cooling end) has gotten damaged. While looking at the manuals (I have the op and inter. manual but not the parts manual) I have decided to start searching for the blower fan and parts along with the stator but I do not have the part numbers for such. I found a parts man. on line but it would not down load right. Any help would be greatly appreciated. By the way what voltage did the civillian engines run on 12V or 24V ? Thankyou, Mark H.
MEP003A Gensets are 24 Vdc, while their civilian counterparts are mostly
12 Vdc. The Cooling tins, should be interchangeable between the Military and civilian models, where as the Genend, AVR, and external Metering and Electrics are NOT interchangeable.
Bruce in alaska
The Following User Says Thank You to BTPost:
Bruce thank you very much for the information on the MEP003A genset. Do you have information on the civillain part number for the tin end ? Thank you, Mark H.
Mark,
I believe most of the sheet metal on the MEP is military only and not the same as a 12.5 DJC. I have a couple of the DJC power plants that were used on some sort of pumps used by the military and the sheet metal will not fit the MEP-003A. If you PM me your email address, I can send you the parts manual for the MEP-003A. The MEP-003A also uses an aluminum fan and the power units have cast iron fans. Maybe one of the Onan experts can tell us if the civilian DJC generators use an aluminum or cast iron fan. David |
The Following User Says Thank You to David C:
David,
Thankyou very much for the information and for sending me a copy of the parts manual, this was a tremendous help for me in finding out what civillian parts I can get and what I cannot get. Thankyou again, Mark H. |
Actually, the Tins are the same, but the MEP003A has the Oil Cooler Mod, and
a few other additions that are mounted under the Tins, and if you use a Civie set of Tins, you may have to make some sheet metal Mods for those extras, and David is right there is a Cast Iorn Flywheel, and an Aluminum one, as well. Also of note the MEP003A is likely NOT an Onan DJC, but more likely an Onan DJF. The difference being in the Bore size of the cyl. the later in the Production Cycle, the more likely it is a DJF.
Bruce in alaska
Bruce, Thankyou for the info I hope to have what I might need, I picked up a complete used MEP engine I have to get it next week. Do you know the difference in bore size between the DJC and DJF ? Thankyou Mark
David is correct, the DJC is 3.25" Bore, and the DJF has a 3.5" Bore. A lot
of folks assume that the MEP003A is a DJC, but in reality it is a DJF.
Bruce in alaska
ThankYou to everybody who has helped, I have learned alot but need to learn some more. So with that in hand does anybody have a source for filters of any type for theses units. Also recomendation on weight of oil for the crankcase. I live in the North East Niagara Falls, Buffalo NY area. Your help would be greatly appreciated. Thank You Mark H.
Onan used to have a Delo 100 30Wt for Lubeoil Spec, back in the day when I
had twin DJC's as my main Prime Power Units. This was long before Multi-Grade Lubricants were around. Now days I use Delo 400 15W40, in ALL my diesel Units, even when it is well below Zero outside. This has proved to be a very good LubeOil for me, as I have just retired twin 20Kw Northern Lights Gensets, with over 60K operating hours, each. I hope to get similar lifetimes from my new twin N844LW2 Northern Lights 20Kw Gensets, that are just passed Break-in, with 3K operating hours, Each.
Bruce in alaska
Filters for the MEP003 are readily available from a number of sources. I get mine at NAPA, but I suppose the others are just as good. I found only a Fram source for the fuel strainer, but it doesn't really ever need to be replaced; it is made of thin metal plates and can be cleaned with carb cleaner or similar solvents to be just like new.
Oil Filter: NAPA 1004, Wix 202 C, Fram CH6PL, MS35802-2 NSN 2940-00-580-6304 Fuel Filter cartridge: NAPA 3113, Fram C1125PL NSN 2910-00-287-1930 Fuel Strainer cartridge: Fram 35070 NSN 2910-00-222-2216 Air Filter cartridge: NAPA FIL 2222, Donaldson P10-1222, FleetGuard AF437KM Richard |
The Following User Says Thank You to RichardR:
Peyton |
Group,
I have a parts manuals for the MEP-003A in a PDF file. I can email it to you if you need. Sorry I have net been checking the boards much latley, as I have have been researching building an electric car (S-10). I have also been trying to work on my airplanes (L-5 and Yak-52) J fischer fish@aviation-tech.com |
The Following User Says Thank You to J. Fischer:
you might try a hastings ff906,or baldwin pf906. they are 3inchs OD,1 1/16 inch ID, 3 5/8 inchs long,these cross with the 33113 wix and c1125pl fram,
REGARDS
The Following User Says Thank You to Tom Kilgore:
| MEP003A voltage variation | Dave B10 | Onan Generators | 11 | 01-07-2008 11:01 PM |
| Part numbers / Ignition parts | John A | Onan Generators | 1 | 09-15-2007 11:10 PM |
| A MEP003A newbie with q's... | red pill | Onan Generators | 5 | 03-26-2007 02:31 AM |
| How Much Noise Does A MEP003A Makes?? | Doogdoog | Military MEP and Aircraft Gen-Sets | 2 | 09-03-2006 03:32 AM |
| Who's engine parts had the part numbers cast into them? | Pat Barrett | Antique Engine Archives | 18 | 11-29-2004 10:26 AM |
