Another Homelite Aircraft APU
I picked up an old model KS-15075 "Engine Alternator" 1.5KW Genset. It's 115V and even came with a...
this thread has 10 replies and has been viewed 1264 times
Old 05-22-2008, 09:43 PM
Nazrat Nazrat is offline
Default Another Homelite Aircraft APU
I picked up an old model KS-15075 "Engine Alternator" 1.5KW Genset. It's 115V and even came with a power cord that has a connector that plugs into one of the three factory outlets. The Homelite tag calls it model 13A115-17
Insides look good too:
Next step is to flush out the fuel tank, look for the lube points and give it a shot.
-Tad
Old 05-22-2008, 09:45 PM
Default Re: Another Homelite Aircraft APU
Oh, if anyone has a spare cover plate for that bottom part of the alternator end, I'd like to buy it.
I saw the posts before with different views on the weight of oil needed, this one clearly calls for 30wt.
-Tad
Old 07-29-2008, 10:52 PM
Krazy8 Krazy8 is offline
Hi, I have an Identical generator same model and everything. the only difference is that mine has a standard wall plug on the bottom panel below the large outlet. the engine was seized up on mine and i'm giving it an entire Rebuild/Restoration. if you know where to get crankrod bearings, plz let me know!
Krazy8
Old 07-30-2008, 06:49 AM
Only problem with mine so far is that the fuel shut-off is rusted in the on position. Once you've removed the gas tank I'd appreciate any pointers on its removal.
I have no info on the bearings, sorry. Probably best to remove them and take them somewhere.
-Tad
Old 07-30-2008, 06:13 PM
to get the gas tank off, you need to take the genset off the springs and baseplate. then you need to remove the carb with those two bolts that attatch to the engine, and just lift it out.
as forthe fuel valve, just loosen it with a wrench. mine was stuck too so it should work. Email me if you need any more help. Mr.Studz@yahoo.com
Old 07-30-2008, 06:17 PM
Oh! and dont forget to take the fuel hoses off the carb!
Old 08-02-2008, 07:05 PM
I just honed out the cylinder and once I put a new gasket on the head, it'll be ready to run. I just need to pick up some AVgas, and then i'll give it a shot. Could you get a picture of the choke knob for me? mine is missing one and i need to replace it.
Old 11-29-2008, 07:40 PM
Any updates? I've been soaking my shut-off in penetrant for a month and it moves about 1/8 turn now. Is that correct? I was assuming it was a 1/4 turn ball type valve. Also, what position is on vs. off?
Avgas? I was going to get some high-octane gas. I think my label says 90 octane or higher.
-Tad
Old 12-02-2008, 08:32 PM
I managed to get the fuel shut-off freed up. Only thing left before starting it (or at least trying to) is the fuel filter. I removed it and the filter material was basically dust. What should I use to replace it? Some t-shirt material? This is the kind of filter with a metal mesh-like plug covered in some (now gone) material then wrapped in wire to keep the filter in place.
Thanks,
Tad
Old 12-03-2008, 11:15 PM
-Tad
There is guy selling some parts for a similar unit on eBay, right now. He is offering a cylinder, a cylinder cooling shroud, an ammeter, etc.
While he may not be currently selling the parts you need and his unit may differ from yours in other respects, you might email him and see if he has something you're looking for.
Don't wait around to look, though. The auctions will close before you know it.
(I have NO connection with the auction or seller.)
Old 08-19-2009, 08:52 AM
duaneross duaneross is offline
hi i have that engine in like new shape no carb or gas tank give me a call if you want it duane 408 648-5429 thanks
Aircraft Generator No Output! SteveL Generators & Motors General Discussion 18 01-09-2008 04:51 AM
Warner Aircraft Corp engine?? Junkologist Small Air Cooled Gasoline Engines 4 12-17-2007 10:40 PM
Aircraft Generator Welder RPM SteveL Welding Shop 2 09-13-2007 12:22 AM
Aircraft Cooling Fan From WW II Charlie Allen Antique Engine Archives 0 10-23-2004 11:46 PM
aircraft engine Robert Johnson Antique Engine Archives 7 02-22-2001 02:36 AM
