Big ol' 25KW diesel mil genset info...I have a big ol' vintage 1944 25KW rated 1,200 RPM 6 pole 3 phase 240V delta skid mounted ex-mil...this thread has 4 replies and has been viewed 876 times
I have a big ol' vintage 1944 25KW rated 1,200 RPM 6 pole 3 phase 240V delta skid mounted ex-mil genset.
It has an International UD-9 diesel engine (very interesting engine) which I have the service manual for, but I do not have any documentation for the rest of the unit. The unit is some distance from me at the moment, so I don't have all the numbers handy unfortunately. Just wondering if anyone knows anything about these units and/or where I can find more documentation. Thanks, Pete C. |
You might ask the Moderator to move this thread over to the Military
Generator Forum, in the Motor & Generator Section, as it would get more play over there, I believe.
Bruce in alaska
I'm pretty sure its a Kato gen end. Do you have the voltage regulator? Here is a number for Kato. It is possible that they will still have documentation for the generator. 501-625-4011
The area code may be 507 or 501 I can't read my hand writing. I used to have a 1200 RPM Kato Gen end but I didn't have a the voltage regulator and I couldn't figure out another way to regulate the voltage. |
The Signal Corps PE-85-M is powered by the UD-9 engine as you describe directly driving a Continental Electric S-105-X AC generator 3 phase 3 wire 2 bearing unit. Total weight crated 5400 lbs. Skid mounting with open frame. Technical Manual TM 11-916-M. (1945 information)
can i ask how much to have in it ???
| 3-71 GM Diesel GenSet | Roger Boardman | Generators & Motors General Discussion | 13 | 07-11-2008 10:48 PM |
| Anybody ID this Diesel Genset | BTPost | Generators & Motors General Discussion | 3 | 12-20-2005 04:13 AM |
| Lister diesel genset info needed | Robt. | Vintage Diesel Engines | 9 | 05-30-2005 02:12 AM |
| 3KW diesel Genset, Onan | Rb Hawaii | Onan Generators | 0 | 07-01-2003 02:55 AM |
| Witte Diesel genset | Gus Simms | Antique Engine Archives | 3 | 10-03-2001 11:17 PM |
