Flame Licker ToyI picked up a toy flame licker engine a week ago & can't seem to find much information on it....this thread has 11 replies and has been viewed 2752 times
I picked up a toy flame licker engine a week ago & can't seem to find much information on it. Flywheels are 3 1/2" diameter. There is a patent date cast in base of Nov 20 19?? I can't read the last two digits. Next to last may be a 0 or 6. One guy thought it might be an Arcade in the 1960's.
It appears to be complete & I'd like to run it. Propane? Natural gas? or did it run on producer gas? Acetylene? What would I need for a regulator to run it on propane? |
Doug; Your engine is a Paradox. It was made to run on illuminating gas. It is a three cycle engine , the first 1/3 rd of the stroke is the intake then the piston opens the touch hole to fire for the power stroke 2 nd 2/3 rds , then the exhaust stroke They can be run best on a special gas mix of 60% hydrogen , 30%methane , 10%carbon monxide. There is a great video on Utube. Also do a forum search here. Ron
The Following User Says Thank You to Ronald E. McClellan:
The Following 3 Users Say Thank You to Ronald E. McClellan:
was this type of ignition ever used on a "real" engine?
Andy Glines 16 HP Huber # 8213 19 HP Keck-Gonnerman # 1789 "There's just something about steam!" |
The closest that I can think of is the Otto and Crossley four cycle engines with slide valve flame ignation where the slide valve carried the flame into the combustion chamber. Ron
Yes that is a paradox engine. Someplace I have a copy of the patent information for them, am in the proccess of moving so I am not sure where the papers are. But I found these pics on the internet. The patent date looks to be around 1900 on these pics, or at least to my tired monitor and eyes.
I have seen them run on acetylene gas before with good results. Don't let anyone try to sucker you out of it, the last one I watched sell brought over $500, and that was 6 or 7 years ago! |
Hello Dough,
We had a threat on the paradox engine on Harry's old gas engine forum.http://www.smokstak.com/forum/showth...hlight=paradox Ours ran once in Nuenen someone brought the right mixture of gas and we brought our engine. I had been looking for a toy stationary engine for 25 years and then found 2 in 1 week. This paradox is the smallest, the other toy was a kogel & fugs. Friendly regards Jeanne www.2oostvogels.nl |
Hey Doug, The Paradox also comes in a tank cooled version. There are not to many out there I do have one, I also just got this 4 cycle sideshaft english version called the "LEEK" engine made by th British Engineering & Eletrical Co. in the area of Leek UK. they started around 1882 and made these engines as kits and were making them until around the 1905 time frame. Mike
The Following 2 Users Say Thank You to Mike O:
Here are pictures of my "tank cooled" Paradox
Mike; What you have here is a Schoenner engine made in Germany. It's not 4 cycle (note the 1:1 gears for the side shaft). It works about the same as the paradox but much more complicated like other German toys. Schoenner made 2 different size sideshaft and one push rod engines. Youtrs is missing one flywheel. Ron
I hope this letter comes through ledgable, I am aware of the german engines you talk about however this one is a LEEK made in the UK. If you happen to have the english engines A to Z you will find a lot more about there engines thhere also. That is the british version of our BYB, You will also note on my engine there is a mecanical intake and exhost valve. They also talk about it being improved to run on the "OTTO" cycle today known as 4 cycle. I am wondering if in fact I am missing a flywheel, as most english engines do only have 1. In the different books I have looked up it does seem that all the pictures show 2 but they are also 6 spoke and my engine is 8 spokes? and there is NO room on the other side of the crank to mount a 2nd and to me it looks like it has always been that way. MIke
Mike; I have the book and have seen the picture. I am sure that the picture is wrong. I wonder if some of our English friends could chime in here with a picture of the 1/12 HP engine. The picture that I sent is an 8 spoke F.W. That is a Schoenner engine and would not develop 1/12 HP. It can not be 4 cycle because of the 1 : 1 gear ratio for the side shaft. Ron
| Flame licker model engine , Vacuum Rotor Dayton O. | TBuchanan | Scale Model Engineering | 10 | 02-20-2009 05:31 PM |
| Fire Eater (flame licker) | Dan Parry | Scale Model Engineering | 6 | 04-21-2008 03:34 PM |
| Baraboo Flame Licker | Steve Barr | Antique Engine Archives | 0 | 08-23-2004 11:46 AM |
| Maytag flame thrower | Vernon | Antique Engine Archives | 14 | 06-14-2003 10:36 AM |
| Flame Licker in Japan. | Bill Tremel | Antique Engine Archives | 1 | 11-03-2002 10:26 PM |
