Antique Tractor Talk Vintage farm tractors and mounted implements. Ford, John Deere, Oliver, McCormick and more.
Detroit Tractor Co. 44-16
my brother bought this a few years ago. its a detroit tractor co 44-16 made in either 1947 or 1948 ...
this thread has 7 replies and has been viewed 4786 times
Old 06-22-2008, 05:11 PM
cjrolke cjrolke is offline
Default Detroit Tractor Co. 44-16
http://rolke.dyndns.org/ftp/Detroit%...%20(Small).JPG
its kind of like a antique version of a bobcat type skid steer
chain drive to the rubber tires and each side
the motor is a continental 4 cylinder
the steering is brakes on a shaft that controls the chains
there is supposed to be fenders over the wheels that we think is diamond plate
this unit has a loader on it that kind of looks home made
it also has a cast aluminum hood
we recently found that there was records of this company after 1949
anyone know anything about this??
we would eventually like to get it running and drivable
thanks for any info about this
Old 06-22-2008, 05:13 PM
Default Re: Detroit Tractor Co. 44-16
another pic
Old 06-22-2008, 05:15 PM
its rough but complete
Old 06-23-2008, 01:00 PM
May have a little info on the engine--I have a note (tho I failed to note the source) that they came with a Cont N62, a fairly popular little 23/4 x 31/2.
If parts for it not available locally, the most recommended source is Montes' Equipment in Chicago; Gerrad Moon is described as the contact person (gerradmoon@montes@flash.net).
You'll need your engine serial #, as a 93 Clevite bearing catalog shows a rod insert change at eng #42049 (engines before #42049 and engines after #42049). Mains stay the same per this catalog.
(I always wonder what eng # 42049 takes!). Good luck.
Old 06-23-2008, 01:07 PM
thanks for the info
i will pass it on to my brother
on a side note
i stumbled on to a tractor values book that lists this unit alont with 2 other (more powerful ones) and a restorable one lists at $2500 and goes up to $10000
not bad considering it was bought for scrap prices
Old 06-23-2008, 01:12 PM
Forgot to mention my note says "produced 47-48, was four wheel drive, and weighed about 1660 lbs", but I didn't note if that was just tractor or with anything attached.
If you advertise for parts include prod date or info to differentiate from the 1914 or so Detroit (Detroit Tractor Co, LaFayette, IN), which was one of the attempts at a line-drive "transitional" tractor (operator rode implement, the "tractor" replaced the horse, operated by reins/lines held by operator).
Old 09-23-2008, 09:15 PM
redneckengineer redneckengineer is offline
May have talked to you a few years back on YT. I have a loader version of the model 44-16 as well, however mine is set up the reverse of yours. More like a modern skidsteer.
Old 09-24-2008, 06:43 AM
dont know if we have or not
but i will forward this off to my brother
can you get some more pictures of yours
just all over and around shots
thanks
Nelson Brothers, Detroit Engine Co., Detroit Engine Works. John Davis Antique Gas Engine Discussion 3 04-01-2008 06:59 PM
Detroit Engine Works, Wadsworth Tractor John Davis Antique Tractor Talk 0 01-24-2007 11:50 AM
Detroit Engine Works, Wadsworth Tractor John Davis Antique Gas Engine Discussion 0 01-24-2007 11:26 AM
? about a Detroit Randy Stafford Antique Engine Archives 9 01-27-2004 09:40 PM
Detroit 4-53 Al Steppich Antique Engine Archives 9 12-02-2003 10:28 PM
