Info on Sears generator
HELP; I have a sears 5000 watt gen. that I need manuels for, the only numbers I can find are on the...
this thread has 3 replies and has been viewed 960 times
Old 06-25-2008, 11:00 AM
Tom Kilgore Tom Kilgore is offline
Arrow Info on Sears generator
HELP; I have a sears 5000 watt gen. that I need manuels for, the only numbers I can find are on the gen. 580-328250 it has a 1cyl 357cc engine no name such as tec. or briggs on it. It is a little unique that it has a oil resevoir to add oil to motor if it gets low also has hook up to run off tank gas or extra remote tank. I would like to know who made this for sears? and where I might find info about it.:wav THANKS GUYS Tom
Old 06-25-2008, 02:42 PM
Default Re: Info on Sears generator
back to top I still need help
Old 06-25-2008, 03:01 PM
Fred M. Fred M. is offline
Tom-
Go to the Sears web site and click on Parts. Then search by model number, using 580.328250. If you are lucky, an owners manual will be available that has information on both the generator and engine.
The 580 is Sears' source code for Generac. You will note that many parts are listed as discontinued by Sears. However, they may still be available through other sources, since Sears uses the Generac part numbers. (Sometimes you have to add "GS" to the end of the part number, as a result of Briggs & Stratton's purchase of Generac's portable generator division.)
I recently purchased parts for my Sears generator from a local Generac dealer.
Fred
The Following User Says Thank You to Fred M.:
Old 06-26-2008, 09:43 AM
K D Redd K D Redd is offline
B&S bought Generac's generators up through 12.5 KW I think. The engine may be a Generac engine.
Kent
The Following User Says Thank You to K D Redd:
Sears and Roebuck Generator JG4608 Generators & Motors General Discussion 4 05-30-2008 10:09 AM
Sears Generator with 2 Cyl Wisconsin Jud Generac Generators (SEARS, etc.) 11 03-08-2007 09:50 AM
Sears Seebrite Generator Jeff Generators & Motors General Discussion 7 08-22-2005 02:29 PM
Sears generator Royce Gaylord Generac Generators (SEARS, etc.) 5 07-26-2003 02:31 AM
Sears Seebrite Generator Jeff Conner Generators & Motors General Discussion 0 08-31-2002 10:45 PM
