Go Back   SmokStak > SmokStak® General Discussion > Alternative Fuels
Alternative Fuels
2 stroke mix for Hit and Miss?
A friend of mine gave me a couple gallons of typical 2 stroke engine mix, it is 87 octane and...
this thread has 3 replies and has been viewed 1146 times
Old 06-26-2008, 01:08 AM
flasks flasks is offline
Default 2 stroke mix for Hit and Miss?
A friend of mine gave me a couple gallons of typical 2 stroke engine mix, it is 87 octane and Walmart's brand of 3-stroke oil but he couldn't remember the mix ration whether it was 32-1 or 50-1. My small hit and miss engine will run fine on straight 87 octane but I am hoping it will run on this mix I was given. Before I put this in the tank have any of you guys run a two cycle mix in a hit and mix and was were the results...power loss?, slower running? anything different other than I might expect other than a little exhaust smoke. Thanks
Old 06-26-2008, 02:10 AM
Bill Wehrman Bill Wehrman is offline
Defective Email Address
Default Re: 2 stroke mix for Hit and Miss??
Run it, I doubt if you will ever be able to tell the difference except for the smell and maby a little smoke but the newer stuff doesn't smoke much anyway. I run out all the time and have to use my mixed fuel, have probably had some in every gasoline engine I have. It seems to last a little longer in the can too.
The Following User Says Thank You to Bill Wehrman:
Old 07-28-2008, 12:58 AM
Exclamation Re: 2 stroke mix for Hit and Miss??
You will get lots of top end lubrication!
Old 07-28-2008, 11:02 AM
Elden DuRand's Avatar
Images: 6
Flasks:
If you don't like the smoke or smell, just dilute it a few times with straight pump gasoline and you should minimize the irritation.
Take care - Elden
http://www.oldengine.org/members/durand/
The Following User Says Thank You to Elden DuRand:
Model 2-stroke...almost done. nar Scale Model Engineering 4 04-01-2008 10:05 PM
Will two stroke oil work? bjaspud Maytag Engine Collectibles 17 10-15-2007 12:40 PM
Bore and stroke Jordan Antique Gas Engine Discussion 13 12-11-2005 08:53 PM
2 stroke problem Austen Small Air Cooled Gasoline Engines 16 11-30-2005 12:06 AM
The Mogul Runs! Hit & Miss,Miss,Miss, Miss,Miss Dan Bogart Antique Engine Archives 7 06-24-2003 01:10 AM
