Engine oil specs old Briggs and Stratton
this thread has 4 replies and has been viewed 2713 times
Old 07-01-2008, 10:17:45 PM
Dewayne Isaacs Dewayne Isaacs is offline
Cool Engine oil specs old Briggs and Stratton
hi guys: i need some info ive got and old montgomery wards power trac garden plow aka simplicity about 1957 7 horse i have never changed the oil since ive owned it i figure its about time for some pm on the data plate it says to use a 20w oil depending on ambient temp in the local since i live in middle ga. where temps range from approx. 20 in the winter and 100 in the summer whats the best possible oil to use and what exact weight detergent or non detergent im affraid i know very little about whats best for older engines? i still use this workhorse for gardening and want to continue to do so. thanks wayne
Old 07-01-2008, 11:29:06 PM
The one banger boy The one banger boy is offline
Default Re: Engine oil specs old Briggs and Stratton
Any modern oil is better than what they had then. My tags say 10w if below 32 and 20w if above. I use 30w castrol or briggs and stratton 30w. They all work as long as your level is right.
The Following User Says Thank You to The one banger boy For This Post:
Old 07-01-2008, 11:29:21 PM
I use nothing but heavy duty #30 detergent oil in all my 4 cycle air cooled engines for summer use. Currently that's Co-op brand DMO - (Diesel Motor Oil). Been using the same stuff in the employer's John Deere 4240 tractor for last 20 years or so. It's on the verge of turning over 13,000 hours and engine has never been opened up and never add oil between changes.
When temperatures dip below freezing would suggest switching to 10W30 or if really cold, below zero F, you might want to go with 0W30 or 0W40 synthetic.
Now if the engine has been run on non detergent oil, you will probably want to stay with that, but I would still use #30 rather than a multigrade for summer temperatures.
Bill
The Following User Says Thank You to Bill Sherlock For This Post:
Old 07-01-2008, 11:39:33 PM
Don Naismith Don Naismith is offline
50 year old engine. You might want to consider removing the base of the engine to remove any sludge that's accumulated over the years. If there's sludge and you use a detergent oil you'll run the risk of damaging the engine.
The Following User Says Thank You to Don Naismith For This Post:
Old 07-02-2008, 09:50:57 AM
CJBennett CJBennett is offline
Briggs recomends 5w-30 for winter oil in their engines. 30w for the summer.
The Following User Says Thank You to CJBennett For This Post:
Briggs & Stratton snowblower engine recall Bill Rogers Small Air Cooled Gasoline Engines 3 05-02-2007 11:25:41 AM
From when is this Briggs & Stratton engine? Nork Small Air Cooled Gasoline Engines 12 11-17-2005 09:18:30 PM
Briggs & Stratton 8AHF engine Mike in NC Small Air Cooled Gasoline Engines 2 05-07-2005 01:37:06 AM
Briggs + Stratton Upright Engine off a Moto Mower? Chad Schlifke Antique Engine Archives 6 11-24-2003 10:45:59 PM
Briggs & Stratton FH Engine Bill Sherlock Antique Engine Archives 5 12-12-2002 11:06:59 PM
