Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps, washers and antiquities of the industrial revolution.
Corn binder knife section?
I have a Mccormick-Deering one row, ground-driven corn binder. I've been trying to locate a new...
this thread has 10 replies and has been viewed 3888 times
Old 07-10-2008, 06:17 AM
farmsc's Avatar
farmsc farmsc is offline
Default Corn binder restoration pics..
I have a Mccormick-Deering one row, ground-driven corn binder. I've been trying to locate a new sickle-knife for it and not having much luck. The old part # was c-143, which CNH says was a good #, but it is no longer available. Anyone have a NOS one laying around or know of a source for one?
Kevin
This is a before picture.
I'll post one later of my progress if anyone is interested.
The Following User Says Thank You to farmsc:
Old 07-10-2008, 08:19 AM
Virginia Mike Virginia Mike is offline
Default Re: Corn binder knife section?
Aren't they just a heavy-duty mower section? A mower knife would probaly work for demos.
Best,
Mike
Old 07-10-2008, 03:54 PM
farmsc's Avatar
I have the old one, but it's wore out, beyond what I believe would take a good sharpening. Also, it's not just for demos, I use it every year to harvest my sorghum for syrupmaking.
Kevin
Old 07-10-2008, 06:24 PM
LeRoy IHC LeRoy IHC is offline
Card Sponsor
Hello
I'm sure you can get any parts you need for your McCormick Corn Binder from General Repair Shop located at 63 Old Leacock Rd. Ronks, Pa. 717-768-3902 or Voice Mail 717-656-1967
They even have brand new knotters. They completely rebuilt my binder with new sprockets, chains, cutter section like you're looking for and numerous other parts that were worn out. The amish still use these binders to harvest their corn in Lancaster, County.
Good luck and post on here how you make out.
LeRoy Baumgardner
The Following 2 Users Say Thank You to LeRoy IHC:
Old 07-10-2008, 07:40 PM
farmsc's Avatar
Yep, I don't know why I didn't call them in the first place. I bought my wood and also a replacement binder dog from them, already. I called 'em up this afternoon and they said they'd get me one right out.
Here is a picture of the binder cutting cane in2006
Old 07-10-2008, 07:57 PM
farmsc's Avatar
Here's a shot of the restoration show so far...
Old 07-15-2008, 08:28 PM
farmsc's Avatar
Thought I'd post another update pic.
Just a few loose ends to tie up and I'll be ready for a test run in the corn field. Before I tore it down, it worked rather well, only it wouldn't always lock out after each bundle. It would make one nice full one, then it would just keep cycling. Sometimes you would have a good full one, then you'd get 1 stalk. BUT, the knotter worked SO well, even the one stalk eould have a good knot on it. I replaced the lock-out dog while I had it apart, so I hope that fixed it.
Old 07-17-2008, 10:29 AM
Pitalplace's Avatar
Pitalplace Pitalplace is offline
I have one that I will be restoring in a few years so your story and photos were great.
Old 09-28-2009, 06:47 PM
OliverPaine OliverPaine is offline
This should probably be a new thread but I need some help. I have the same corn binder as this thread. My problem is that it won't bind correctly. It will tie great but then the needle will go back and stop at the knotter. Of course corn backs up behind the needle and the whole thing plugs up. I replaced the dog on the driving disk (clutch) but it still goes around and some times stops and other times just continues around. Any ideas?
Old 01-25-2010, 08:38 PM
Lawson Lawson is offline
Default Re: Corn binder restoration pics..
Is your corn Binder a McCormick-Deering or a McCormick. I have a McCormick and just learned the difference. I don't have grease fittings on mine.
kooncejp@somtel.net
Old Yesterday, 06:35 AM
Ossahatchee Ossahatchee is offline
Hello,
I am new to this forum and a new owner of a corn binder. I realize this is an old thread but it ends with a question that I need to know the answer to in order to start my restoration project. My corn binder has only International harvester insignias and a nameplate CB 702. I would like to obtain a manual but need to know which one. It seems that McCormick Corn Binders have IH insignias as well which leads to my confusion. I would appreciate any advice and information pertaining to identifying which model I have and any tips in general. I plan to use this corn binder to harvest Sweet Sorghum for Syrup making.
Thanks,
Forrest
Knife Switch Tom Antique Engine Archives 7 06-03-2004 09:43 AM
Meco/under the knife sean Antique Engine Archives 0 07-31-2002 06:48 PM
knife switches bill schaller Antique Engine Archives 5 03-27-2002 06:44 PM
Knife switches Alan James Antique Engine Archives 14 05-07-2001 03:15 PM
knife switch Kevin A. Behnke Antique Engine Archives 4 05-03-2001 09:02 PM
