Wisconsin Engines
Bobcat VH4D vapor lock?
this thread has 12 replies and has been viewed 10400 times
Old 07-21-2008, 09:40:55 PM
retmsg retmsg is offline
Question Bobcat VH4D vapor lock?
Help my bobcat 610 runs great for about 10 min then she falls on her nose, The only way to keep it going is to choke it. I have replaced the fuel lines from 1/4 to 3/8 and insulated the fuel lines. I have converted the fuel pump from mech to electric and have a consent supply of fuel. She ran great all winter and did not have this problem untill I started to work it in the heat, Any ideas ???
Old 07-21-2008, 11:11:27 PM
Default Re: VH4D vapor lock?
If the engine is non original to this machine,then look at the intake,exhaust manifold to see if they are cast as one piece.if they are then use a saw to separate them.When you look at them you will see where to cut.This is the factory recommendation to solve carb boiling problems.There is no need to remove them for this.Also be sure the fuel tank vent is open.
Old 07-22-2008, 08:24:57 AM
K D Redd K D Redd is offline
Have you looked at your ignition system also? Sometime an ignition problem can mask itself as a fuel system problem even do to pulling the choke will keep the rnginr running.
Kent
Old 07-22-2008, 09:39:41 AM
Elden DuRand's Avatar
Images: 6
Also check to make sure the gas tank vent is not clogged.
Take care - Elden
Old 07-22-2008, 06:25:46 PM
Zira Zira is offline
Default Re: Bobcat VH4D vapor lock?
If this is a coil/distributer ignition, try replacing the coil.
Old 07-22-2008, 07:32:58 PM
JHFoster JHFoster is offline
These points/condenser are harder to change then the old fords tractors with the dist. in front of the engine. The last time I changed mine in my bobcat I pulled the motor.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Old 07-23-2008, 08:16:10 PM
Thanks for your input on seperating the manifolds I thought it was a poor design. I think that this engine is OEM, I have refilled my FUEL tank and feel I have gotten some poor fuel as I ran it hard for 1hr @ 90 deg with no problems. Is the manifold modification only on bobcat applications ??.
Old 07-23-2008, 08:22:10 PM
My dist is in the back of the bobcat and easy access when I open the door
Old 07-25-2008, 09:39:07 PM
The modification applied to any application that developed the problem.
Old 07-04-2009, 03:58:59 PM
JameySmith JameySmith is offline
I had the same problem with my melroe 610 and the oil seal on the distributor was bad so the engine was pumping oil up into the points causing poor ignition
Old 05-10-2010, 03:47:11 PM
brwracing brwracing is offline
I have a bobcat 720 with a tired vf4d 30 horse engine.
Is it worth keeping this old engine running?
Old 05-10-2010, 04:57:57 PM
Dempster Dempster is offline
You'll spend as much either way fixing the engine you have or trying to convert it with a small diesel like used in the newer ones today.
Old 05-10-2010, 05:10:21 PM
Arrow Re: Bobcat VH4D vapor lock?
This illustration from a Wisconsin VG4D manual shows where to make hack saw cuts on a manifold on a engine that will be ran mostly in hot weather and suffers from hard starting in hot weather.
Wisconsin VH4D Chandler Wisconsin Engines 2 12-29-2007 05:21:56 PM
BobCat 444 clutch adjustment BrainAllinger Antique Farm Tractors 6 10-03-2007 09:12:58 AM
Is this vapor lock or something else? AlanD Generators & Motors General Discussion 10 11-29-2005 02:02:21 PM
Model 7CM21-RV Vapor Lock WilliamR Kohler Generators 7 07-24-2005 03:08:17 AM
THD engine in 444 bobcat Paul Robinson Antique Engine Archives 0 03-15-2004 11:41:37 PM
