Craftsman 3200 generatorI have this generator that starts and runs and will run certain electric loads but if a bigger load...this thread has 3 replies and has been viewed 928 times
I have this generator that starts and runs and will run certain electric loads but if a bigger load is applied the engine regulator won't kick in so it just shakes alot and then dies, does anyone have any info to what this could be. I don't know how the accelerator arm works at all(if it is called that).
Can you provide more information as to what loads it will run and what you were trying to use when it failed? Did the engine die or just stop making AC? I am going to guess that it will not handle a large motor type start load. Many motors require quite a large surge current during the start process and many generators cannot handle it. Are the loads that are failing now ever able to work in the past with this generator? Don
Are you calling the engine govener the engine regulator? If so it sounds as if the govener is not adjusted right causing you problem. I Assume your engine is a Tecumseh.
Kent |
Can you post a picture of it?
| Craftsman Generator Parts | Larey | Generac Generators (SEARS, etc.) | 6 | 11-05-2007 11:25 PM |
| Craftsman 143.556072 generator | ncflatfender | Generators & Motors General Discussion | 2 | 10-22-2007 09:36 AM |
| Flywheel Sears Craftsman 3600 generator | ron_a | Generac Generators (SEARS, etc.) | 2 | 04-08-2007 01:19 PM |
| Rectifier board for Craftsman generator | Joe Stewart | Generac Generators (SEARS, etc.) | 22 | 10-12-2006 02:14 AM |
| Old Craftsman saw | MarkG | Chain Saw Collectors | 3 | 06-20-2005 01:21 AM |
