PE-95K w/ 4 cyl. Willys engine - info?
can anyone tell me the weight and dem. of this gen.? it has the 4 cyl. willys engine.was wondering...
this thread has 8 replies and has been viewed 1982 times
Old 08-06-2008, 09:12 PM
Jim Kinler Jim Kinler is offline
Default PE-95K w/ 4 cyl. Willys engine - info?
can anyone tell me the weight and dem. of this gen.? it has the 4 cyl. willys engine.was wondering if a half ton pick up will haul it.
Old 08-07-2008, 09:26 AM
Nicholas Carrier Nicholas Carrier is offline
Default Re: PE-95K w/ 4 cyl. Willys engine - info?
I do not know about the demensions, but I once picked up one with the Willys on it as a spare for my Jeep resteration. If it is around the same size, a half ton pickup should haul it with no problem. Thats just in weight, the dimensions I am not sure of. The particular one I had got, would of fit in a truck, but i put it on a trailer to haul it.
Old 08-07-2008, 07:43 PM
Rich Mc Rich Mc is offline
Depending how much tools, fuel and etc.... it should weight in at 1500-1600 pounds.
Rich
Old 08-08-2008, 04:58 PM
is this pe-95k one of the later versions. i found manuals for the g and h models. none of these are 400 hz. are they?
Old 08-08-2008, 07:26 PM
The K is a modernized G and uses TM 11-904 with supplement C1 (73 pgs) as the tech manual. Produced between the early 50's thru the early 60's. The listed weight is 1682 lbs.
Rich
Old 08-10-2008, 09:01 AM
hey rich do you happen to have that 95-k supplement tm that i can get a copy of? i picked this unit up yesterday very heavy, but truck handled it. i know this unit will connect 120 or 240 volt. can it be wired 120/240 with a nuetral?
Old 08-10-2008, 09:22 PM
Jim I don't have the supplement. I am looking for it also. I did come across this information today about a later Tech Manual. Maybe this manual is the latest info for your unit. Rich
Generator Set
Electric Portable
Gasoline driven
skid mounted, 10 kw
125-250 volt, 1 phase
60 cycle 3 wire
(PE-95K)
Onan model 10 HQ-3R/552B
TM5-5655
Old 08-12-2008, 09:10 PM
anybody familair with ac connections on this set? the head says 120/250 4 wire. yet on the front connection panel theirs onley two terminals. i know it will connect 120 or 240 but i need a nuetral if possible for my house. heck i dont even see a ground either.
Old 12-31-2008, 12:49 PM
Rick Harvey Rick Harvey is offline
NO PROBLEM the P/U will handle it ok. I think it was between 850 and 1000 if I remember right. There should be a weight printed on a name plate somewhere on it also.
Rick
PU 58/G Gen with Willys Engine bluebluejays Military MEP and Aircraft Gen-Sets 2 11-05-2011 01:35 PM
Looking for WWII Willys engine powered Genset macjeeper Military MEP and Aircraft Gen-Sets 21 04-14-2011 08:08 AM
Would like info on Willys Jeep engine governors uglyjeep Antique Gas Engine Discussion 2 02-28-2008 01:33 PM
willys knight Lawrence Musgrave Generators & Motors General Discussion 1 08-03-2002 10:52 PM
Willys Light Engine Adam Cottrill Antique Engine Archives 6 03-25-2002 06:00 AM
