Wiring a Pittsfield coilI have a pittsfield coil similar to a ford buzz coil? and i would like to know how it gets wired up...this thread has 6 replies and has been viewed 439 times
I have a pittsfield coil similar to a ford buzz coil? and i would like to know how it gets wired up so i can use it. I know the spark plug wire goes on the end of the coil as that is where some remains of a old wire were when i bought it a couple of years ago. I wish i had asked the guy i bought it from how to wire it up but all
well. thanks for any help
hi ray,
if it is simillar to a ford t buzz coil, 1 wire to spark plug, negative terminal on battery to your contacts on engine, 1 wire from positive terminal to switch then to coil, 1 wire from coil to ground on the engine (not near your contacts or it will short out) hope this helps some, jordan |
If you know which term. is plug,then the other two don't matter.
Ray: The very, very thin wire
goes goes to the spark terminal . The heaver wires go to the + & - terminals .
"OLDIHC"-Did you make a new friend today, and a lot .
thanks guys. I'll wire it up and see what goes.
I got it working.I had to clean things up on the inside and adjust the point gap to get things right. After tinkering around with it and the battery connections it threw a good spark to the plug.
Could you tell me what the gap should be?
| Battery/coil Magneto Wiring | Tom Martin | Antique Gas Engine Discussion | 4 | 02-23-2008 02:49 AM |
| Buzz Coil Wiring for a 2 Cylinder Edwards Engine? | Larry K | Antique Gas Engine Discussion | 15 | 10-31-2007 12:01 PM |
| model T K-W coil wiring | Canadian made | Antique Gas Engine Discussion | 2 | 04-23-2006 01:51 PM |
| Ford Buzz Coil Wiring/ How much resistance | Ray Cardoza | Magnetos, Ignition Coils and Spark Plugs | 18 | 11-07-2005 11:54 PM |
| Wiring with a buzz coil | Stan | Antique Engine Archives | 2 | 06-21-2001 08:27 PM |
