David Bradley Chainsaw with alternate blade positions
This was at the Roseboom. NY engine show sunday (279 tractors!), normally it would have only one...
this thread has 9 replies and has been viewed 1248 times
Old 08-19-2008, 01:08 AM
Rene Elliott Rene Elliott is offline
Default David Bradley Chainsaw with alternate blade positions
This was at the Roseboom. NY engine show sunday (279 tractors!), normally it would have only one blade, so putting two bars on it really makes you stop and do a doubletake. The exhibitor told me that the saw worked better for bucking, better balanced, with blade near the center, but had the position offset to one side (like modern saws) for trimming closer to the ground.
Old 08-19-2008, 05:33 AM
Sky Pilot Sky Pilot is offline
Default Re: David Bradley Chainsaw with alternate blade positions
I remember Dad's David Bradley with no great amount of affection.
Gear driven, it was almost impossible to stall out ( could be done but you had to work at it) ... its two most endearing features were a diaphragm carburetor (I think I am remembering the term correctly) which let it run laid over on its side or otherwise than dead-upright; the other was its WEIGHT! I think it was 35 pounds or better. You wanted your Wheaties of a morning if you were going to run that saw in the same day!
Oh -- also -- no muffler -- just a ducted port right out of the side of the cylinder. Wear your muffs. I wish I had.
The Following User Says Thank You to Sky Pilot:
Old 08-19-2008, 01:48 PM
jerryjones jerryjones is offline
I have a old David Dradley saw just like the one in the pic. You can move the bar from the inside to the outside, or have two bars like in the pic. Don't know why the two bars but it looks mean.
Old 08-19-2008, 02:38 PM
bstrucker's Avatar
bstrucker bstrucker is offline
Images: 97
I can picture the part about it being easier to operate for bucking with the blade in the center but I can't picture anything that you would use the 2 blades for,unless they had some kind of a milling attachment for making fence posts or something like that.
Butch
video of my Maytag washing machine,
http://flickr.com/photos/beau5278/2583143859/
Old 08-19-2008, 09:33 PM
The exhibitor said it was not meant to be used with two blades, they just set it up for show with two blades to get your attention, which it does.
Old 08-19-2008, 10:06 PM
MoRo's Avatar
MoRo MoRo is offline
Ohhhhhhhhhh, I dunno. It looks like that two-bar setup would work just about right for slicing sausage for a sammich!
Old 08-20-2008, 05:12 PM
Or for one of those tiny box woodstoves.......
Old 09-06-2009, 01:19 PM
davidbradley360 davidbradley360 is offline
old thread but worth reviving, that picture with 2 blades on the saw is knarly
I guess you find just the right size tree trunk to cut into pieces with those 2 blades, not make as many cuts, and have instant firewood without any splitting
Old 09-07-2009, 10:56 PM
....or cut rail holes in fenceposts, or trees for that matter.
Old 09-08-2009, 10:59 PM
caporal30 caporal30 is offline
Talking Re: David Bradley Chainsaw with alternate blade positions
That model was the "360"
One bar for sure.......In the center for a well balanced all position cut.
Bar on the outside for low stump cutting.
This was a gear saw and the sprocket shaft crossed from one side of the transmission to the other.
FOR A JOKE YOU COULD EASILY MOUNT 2 SPROCKETS/BAR/CHAIN ON THE SHAFT and run the saw....
use it to cut sausages ...maybe!!!!!
David Bradley tractor? Sam Simons Garden Tractors / Mowers / Scooters 2 10-27-2007 11:04 PM
david bradley help please justin woodard Antique Gas Engine Discussion 1 10-30-2005 05:53 PM
OT: David Bradley Decal Jebaroni Antique Gas Engine Discussion 0 07-18-2005 10:11 PM
DAVID BRADLEY Ken Fall Antique Engine Archives 3 10-21-2001 11:52 PM
david bradley Jesse Murrah Antique Engine Archives 1 11-26-2000 10:14 PM
