Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
What is correct Transaxle Oil?
this thread has 5 replies and has been viewed 4060 times
Old 09-06-2008, 01:43:52 PM
Bob Naske's Avatar
Bob Naske Bob Naske is offline
Default What is correct Transaxle Oil?
What oil belongs in a 3spd transaxle with Hi-Lo range used in Sears garden tractors?(And probably others). What was left doesn't smell like regular 80-90 gear oil. No manufacturers tag on trans. This is the style that the case splits into left/right sections with input shaft on side of trans,with shifter on top.
Old 09-06-2008, 05:34:49 PM
Elden DuRand's Avatar
Images: 6
Default Re: What is correct Transaxle Oil?
Bob:
On my Hoyt-Clagwell butt buggy, made from a junked Sears Suburban with two speed axle, I've been using 90W gear lube with a dollop of STP. It's been in there for a few years and there are no ill effects.
I figure that if the 90W is good enough for a car, it'll surely be fine for the Sears tranny.
Take care - Elden
Old 09-06-2008, 06:04:44 PM
K D Redd K D Redd is offline
Some use double aught, 00, Zero Zero, grease. Rear engine Snappers use this lube in their gear cases. If there is any yellow metal in theis gear case and you use a transmission/rear end oil DO NOT use a GL-5 oil. GL-4 ,or lower. The GL-5 has a additive for limited slip, posi, rear ends that will attack the yellow metal.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 09-06-2008, 06:13:07 PM
Exclamation Re: What is correct Transaxle Oil?
00 transaxle grease should work fine. If it is a cast iron case, SAE 90 hypoid oil (rear end grease), will work as well.
Old 09-07-2008, 11:04:47 AM
Brian Lynch's Avatar
Images: 24
The original manual that came with my 1972 Sears Suburban 12 states very clearly to use 5 quarts of SAE 30 motor oil for service MM or MS (old classification system) in the transmission. Use any good high quality name brand of SAE 30 HD oil. I've been using it for several years and it has never given so much as a wink of trouble. It shifts easily and solidly into any gear I select, whether I am in hi or low range. The transmission is fairly quiet. I only hear very light gear noise on a grade or when pulling hard on something heavy.
The Following 2 Users Say Thank You to Brian Lynch For This Post:
Old 09-07-2008, 11:38:18 AM
Ditto. If its not the cheapo aluminum transaxles that use Bentonite grease then the iron ones were SAE 30 or EP90 oil.
The Following User Says Thank You to Motormowers For This Post:
Correct oiler for IHC 1 1/2 M Eric McKenna Antique Gas Engine Discussion 4 12-23-2007 04:38:59 PM
Correct Magneto? Tom Martin Antique Gas Engine Discussion 1 06-16-2007 12:21:28 AM
Eaton Hydrostatatic Transaxle Raymond Garden Tractors / Mowers / Scooters 1 10-09-2005 11:11:35 AM
IHC 1hp Famous Correct Mag????? Shane Ball Antique Engine Archives 0 12-12-2004 08:21:15 AM
Correct Carburetor Garry Blevins Antique Engine Archives 3 11-01-2004 08:27:42 PM
