Welding Shop
Lincwelder 225/ Onan problems starting
hello, i bought this welder a few weeks ago and it worked just fine. i charged the batteries and...
this thread has 8 replies and has been viewed 726 times
Old 09-10-2008, 09:58 PM
distinguished1 distinguished1 is offline
Default Lincwelder 225/ Onan problems starting
hello,
i bought this welder a few weeks ago and it worked just fine. i charged the batteries and didnt notice that they were still connected to the solenoid, because of that it got fried and i had to get a new one. once i replaced the solenoid i tried to start the engine but it wont spark. the current goes through and the engine turns but it wont stay on because there is no spark going to the engine. the spark plugs are brand new. im thinking the problem is the magneto but i dont want to buy a new one without asking here first. i just dont know whats going on since it was working great before i replaced the solenoid. any help will be appreciated.
thanks
Old 09-10-2008, 10:39 PM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Images: 260
Default Re: Lincwelder 225/ Onan problems starting
If it has a magneto there is not connection at all to the electrical system. It is a completely different system on its own. Try removing the small wire from the mag and see if it sparks. That wire only grounds out the mag to shut it off. Without it connected it should start and run. If it does the problem lies in your wiring or switch. If it still doesn't have spark try filing the points in the mag.
Leaving the battery charger on should not have damaged the solenoid!
Kelly T
Old 09-10-2008, 11:10 PM
Kimbra Dean Kimbra Dean is offline
Pretty sure this one has a magneto. There is a wire (I think leaving the terminal on the points box) that goes to the on/off switch located near the start button. This on/off switch grounds the ignition circuit to stop the engine. By the way, and I hate to ask this question, but did you turn this switch on (which is actually off or open) when you tried to start the engine.
Old 09-10-2008, 11:36 PM
yeah i checked the switch and double checked that all the wiring was ok.
Old 09-10-2008, 11:43 PM
Kelly T
this welder starts by running 24 volts through the generator and that causes the engine to start. i dont know what you mean by the 'mag' if you mean the spark plug wire, i did check to see if it had a spark, and no spark.
thanks
efren
Old 09-11-2008, 12:43 AM
Images: 260
Mag........Magneto.
Kelly T
Old 09-11-2008, 12:54 AM
OK, if you have an ohm meter do the fallowing:
1. Remove air filter assy to gain access to the points box
2. Remove all wires (2 I think) from terminal on points box
3. Remove cover from front of points box so you can observe
points (be careful not to drop screws down carburetor,
maybee you better cover it up)
4. Check resistance from terminal on points box to ground,
with points open resistance should be infinate
with points closed resistance should be zero
(turn engine by hand as needed to open/close points)
5. Check resistance from wire going to on/off switch to ground
with engine switch in off position resistance should be zero
with switch in on position resistance should be infinate
6. Check resistance from wire going under fan shroud to ground
resistance should not be infinate or zero but I don't know
what it should be
7. If 6 checks OK switch meter to AC volts and check voltage
from this wire to ground while cranking engine, should have
something here but I don't know what, probally more than
just a few volts.
Good Luck
The Following User Says Thank You to Kimbra Dean:
Old 09-12-2008, 11:46 PM
rhank you very much. i will try this and let you know what happens
Old 10-20-2009, 10:04 AM
doug hodgson doug hodgson is offline
never seen a mag on that unit but it sounds like you fried the points
Onan 2.5 AJ Starting problems WilsonsK Onan Generators 10 09-22-2008 05:58 PM
Lincwelder 225 Onan CCK spark problem distinguished1 Onan Generators 4 09-11-2008 11:34 PM
Onan DJE starting problems -- STARTED WORKING ON 'EM ichudov Onan Generators 15 09-09-2007 10:45 PM
Parts manual for Lincwelder 225/3-AS Onan engine HankA Welding Shop 4 07-12-2006 09:43 PM
sTARTING PROBLEMS--AAARRUGHH Ihorse Antique Gas Engine Discussion 13 04-28-2005 11:51 AM
