Onan 6.5 MCCK - Voltage Regulator issue
Hi All, I seem to be getting a weird reading from my 12V voltage regulator. At the C terminal I'm...
this thread has 3 replies and has been viewed 843 times
Old 09-14-2008, 08:26 AM
Aquafennatic Aquafennatic is offline
Question Onan 6.5 MCCK - Voltage Regulator issue
Hi All,
I seem to be getting a weird reading from my 12V voltage regulator. At the C terminal I'm reading 12.6V and at the Batt terminal I'm reading 7.3V. I'm assuming I need to replace the voltage regulator? If so, are these parts easy to find?
FYI I've converted my MCCK Ignition system to an RCCK Ignition system. Seems to work great, however I noticed there was only 7V getting to the positive side of the coil. I think I narrowed it down to the voltage regulator.
Thanks,
Mike
Old 09-14-2008, 09:12 AM
Billy J Shafer's Avatar
Default Re: Onan 6.5 MCCK - Voltage Regulator issue
Need your model and serial number. There are four versions of the MCCK..
Old 09-14-2008, 09:59 AM
It's a 1977 MCCK Spec F. (I don't have the serial # since I'm not at the boat)
Old 09-14-2008, 11:10 AM
Ok I can work with that info.
Voltage issue on 6DJB STxFarmer Onan Generators 13 03-16-2008 03:08 PM
15kw Onan voltage regulator board hoke_weise Onan Generators 15 03-22-2007 06:19 AM
Onan DEG 50.0 voltage regulator issue. Mike Dennis Onan Generators 9 01-21-2007 07:10 PM
Need help with voltage regulator oldtool53 Generators & Motors General Discussion 13 12-11-2006 09:04 PM
Looking for Onan voltage regulator rwenig Onan Generators 0 12-23-2004 10:38 AM
