Remote Oil Filter for Generac Ultra Source 15k
I have a Generac Ultra Source 15k generator with a small spin on oil filter It is powered by 992 cc...
this thread has 1 replies and has been viewed 836 times
Old 09-14-2008, 06:59 PM
Walter J. Walter J. is offline
Default Remote Oil Filter for Generac Ultra Source 15k
I have a Generac Ultra Source 15k generator with a small spin on oil filter It is powered by 992 cc Generac OHVI V-Twin engine . I have found an adaptor plate that will allow the use of a remote oil filter with a larger element. My question does this machine have enough oil pressure to run a larger remote filter? thanks
Old 09-15-2008, 01:09 AM
rrfxxxr rrfxxxr is offline
Default Re: Remote Oil Filter for Generac Ultra Source 15k
I would think a larger filter would be less restrictive than a smaller one. Just more surface area, a little more oil and a little extra cooling effect. All three a plus in my book. The replacement filter needs to be same type (example: by-pass).
You might Tee in a temporary pressure gage on the input, and then move it to the output line and compare the readings. I would guess a delta of few PSI would be normal.
Later
Sbw
4.0 CCK Remote Start DAP Onan Generators 4 07-30-2008 11:34 AM
Remote Cylinder Drains Rick Strobel Stationary Steam & Traction Engines 6 11-25-2007 11:24 AM
Ultra Sonic Cleaners Doug Waggonner Antique Gas Engine Discussion 2 10-31-2007 09:19 PM
Montana Ultra-Sound Testing Rick Strobel Stationary Steam & Traction Engines 8 11-22-2005 12:49 PM
Onan MEP 016B Military Fuel Filter & Air Filter (Help) Doogdoog Onan Generators 8 04-30-2005 10:43 PM
