Parts help for a Sears generator
I'm hoping you can help with a parts problem on my 580326010 sears generator. Long story short is...
this thread has 14 replies and has been viewed 965 times
Old 09-18-2008, 01:45 PM
Joe Joe is offline
Question Parts help for a Sears generator
I'm hoping you can help with a parts problem on my 580326010 sears generator. Long story short is the coil looks like it has a couple hairline cracks in it. The module has melted to a different shape. The root problem is no spark. I found these parts to cost more than I'm willing to invest, and the list I was looking at shows most parts no longer available. Does anyone have any suggestion where to find used parts or a lower cost substitute? Two sources found on line were $200 plus for the coil and from $66 -$140 for the module. Thanks Joe
Old 09-18-2008, 04:12 PM
Gailey Henderson Gailey Henderson is offline
Default Re: Parts help for sears generater
What is the out put the one I have is 1100watts I replaced it with a Honda engine it bolted up and is much more reliable than when the unit was new
The Following User Says Thank You to Gailey Henderson:
Old 09-19-2008, 03:13 PM
Joe Joe is offline
Thumbs up Re: Parts help for sears generater
This unit is 4500 watts. Tell me more about your engine swap? Thanks Joe
Old 09-20-2008, 07:57 PM
K D Redd K D Redd is offline
Is this a Tecumseh engine with the Early Solidstate ignition? If so rhere is a web site called overnight solutins that have a workaround.
Kent
The Following User Says Thank You to K D Redd:
Old 09-22-2008, 09:30 AM
Joe Joe is offline
I will look to see what engine it is. Get back to you when I can. Thanks so much! Joe
Old 09-22-2008, 03:17 PM
Joe Joe is offline
Photo Re: Parts help for sears generater
I could not find any other placard except the one on the Gen. itself. Hoping the JPG's will help. Thanks Joe
Name:	Sears Gen 001.jpg
ID:	40125   Click image for larger version
Name:	Sears Gen 004.jpg
ID:	40126   Click image for larger version
Name:	Sears Gen 002.jpg
ID:	40127   Click image for larger version
Name:	Sears Gen 003.jpg
Old 09-22-2008, 03:54 PM
Tom Kilgore Tom Kilgore is offline
Arrow Re: Parts help for sears generater
I looked up the sears gen and they listed a briggs motor 190707-0887 the coil cost 58.46 briggs part number 298968.regards TOM
The Following User Says Thank You to Tom Kilgore:
Old 09-23-2008, 11:19 AM
disregard this info the sears data is wrong,the briggs engine they referenced is a vertical shaft
Old 09-24-2008, 10:09 AM
Joe,
Could you post a picture of the engine end? All of you picture are of the generator end.
Kent
Old 09-30-2008, 02:29 PM
Joe Joe is offline
Hello, have been away for a few days. I will get the pic’s posted asap! Thanks for your help! Joe
Old 10-07-2008, 03:38 PM
Joe Joe is offline
I found the camera. The engine is covered mostly with metal guards. Right now my storage is limited, so I didn't try taking those off. It is a horizontally opposed engine. Big flywheel under the guard. Hope this helps! Thanks Joe
Name:	Sears eng 001.jpg
ID:	41134   Click image for larger version
Name:	Sears eng 002.jpg
Old 10-07-2008, 08:27 PM
I think the engine is an Onan. Post a picture with the air cleaner removed for a better look at the top of the engine might help. You also might post in the Onan section. If it is an Onan there is a stick post, One that always remains at the top of the page, about electronic ignition conversions. If your coil is bad the re are several option for the part though the flat twin coils are a little special and expensive. I am told you can one from a Harley for about $70. I know one from a flat twin Kohler will work but they are about $120. The good thing is these coils rarely go bag. If this is an Onan the have problems with there points. Again see the conversion to electronic.
Kent
Old 10-15-2008, 01:47 PM
Joe Joe is offline
Default Re: Parts help for a Sears generator
Here are the pic's of the engine with breather removed. Sorry it took so long! Thanks Joe
Name:	top of sears eng.jpg
ID:	41632   Click image for larger version
Name:	Sears Gen eng 002.jpg
ID:	41634   Click image for larger version
Name:	Sears Gen eng 003.jpg
Old 10-16-2008, 10:19 AM
The carb look like a Briggs and Stratton, but the intake manifold being split ( Bolted together ) looks like an ONAN. I do not know what engine you have.
Kent
Old 10-16-2008, 10:21 AM
Joe,
If you were a little closer you could bring this thing by so I could get a better look. I am north of you, 20 miles north of Springfield MO.
Kent
Need help finding parts for Sears motor Dwight S Small Air Cooled Gasoline Engines 4 03-09-2008 09:02 PM
Sears lawn tractor- Onan parts Coolhand Luke Garden Tractors / Mowers / Scooters 0 07-15-2007 12:38 PM
Sears Seebrite Generator Jeff Generators & Motors General Discussion 7 08-22-2005 02:29 PM
Sears generator Royce Gaylord Generac Generators (SEARS, etc.) 5 07-26-2003 02:31 AM
Sears and Roebuck WaterMite Parts Joel Wagner Antique Engine Archives 0 04-05-2001 11:11 PM
