Electric toy steam engineI was wondering what make this steam engine is?Also what kind of stopper would work for this?I...this thread has 7 replies and has been viewed 1247 times
I was wondering what make this steam engine is?Also what kind of stopper would work for this?I think it would have to work as a safety also.
Thanks for any info. Rob |
I believe that is a chimney and should not be plugged. The tube from the back of the cylinder is for exaust I think.
It may be an Indx (sp) but just a guess. Alan I believe that opening you have is for a chimney, and should not be plugged. Is that also the water fill? |
The Following User Says Thank You to Alan R:
I have the same one. It too has the hole where the chimney is. I was told it was the fill hole and thought you removed the whistle. Anyway when you heat it steam escapes through it. Thought about a plug but not sure if a good idea as their is no safety valve? Heats in an instant. Otherwise no one has been able to I.D. the maker. Thanks for the INDX name.
Bob |
The Following User Says Thank You to bobsaunders:
I think a plumb bob shaped valve sits down in the stack and on top of the hole providing a safety. I think you will find the motor will not run until that is in place. If you make one it should be heavy enough to to build pressure. I would make one from brass as steel will rust.
Forrest A |
The Following User Says Thank You to Forrest A:
This is a Watt steam engine.
The Following User Says Thank You to ncseverson:
Thank you so much for the I.D. as an Watt engine. A lot of people look at mine at the tractor show. We did the NIHPA show in Indiana last weekend. The weather was great. Added another mini oscillating engine to my collection.
Bob |
Your display at the NIHPA show was awesome!
Thanks for sharing it.Fred |
| Williams Grove Historical Steam Engine Assoc. Steam School | M Zeigler | Stationary Steam & Traction Engines | 7 | 06-10-2008 08:51 PM |
| Strange, toy electric "steam-like" engine | Reid | Vintage Toy Steam Engines and Motors | 18 | 05-28-2008 03:17 PM |
| Project ! Generating electric from a flywheel gas engine. Help! | Rhino | Generators & Motors General Discussion | 28 | 12-31-2006 07:38 PM |
| Kohler Electric Plant Engine Model L654EP ??? | Rocky Blankenship | Kohler Generators | 2 | 03-30-2003 10:01 AM |
| Globe Electric Co. engine | Bill Miller | Generators & Motors General Discussion | 0 | 07-29-2001 12:56 AM |
