| Vintage Diesel Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines. |
Diagonal Head Bolt SpacingHello, my name is Michael Byrd. I have recently purchased a Jkson (PowerSolutions) 6 HP single...this thread has 1 replies and has been viewed 667 times
a Jkson (PowerSolutions) 6 HP single cylinder diesel engine. Although I have not recieved it yet, I was hoping someone could post the diagonal head bolt dimensions so I can get a lifting bar made. I want to use 2 head bolts to lift by and a bar would be easy for me to make. I know some Indian mfg vary from one to the other so I need this dimension from a Jkson (PowerSolution) 6 HP. I prefer a bar over a chain because of the bar being so rigid and acting like a spreader bar keeping the lifting force axial to the bolts. Any help would be very much appreciated. MB |
I just measured my Vidhata and the spacing is 7 15/16" diagonally, stud diameter is about 3/4". Note that the rocker arm assembly would prevent you from using a straight bar, however it's only held on by two bolts..easily removed and replaced (check clearances after reassembling). As an alternative, you could make up two heavy "eyes" from at least 1/4" x 2" x 4" steel. Drill a 15/16" hole in each end, heat and bend to 90 degrees (L shaped). Remove stud nuts (28mm), install the eye and replace the nuts giving you two lifting points. The cylinder head would serve as the spreader. Remember to retorque to 160-170 ft. lbs. afterwards (takes a BIG torque wrench). Lifting by the head studs is probably the easiest and safest way.
| Briggs 190412 Head bolt pattern question | James Wallace | Small Air Cooled Gasoline Engines | 3 | 09-08-2008 10:50 PM |
| Head Bolt Torque for FM 1-1/2 Z ? | Kevin Pampuch | Antique Gas Engine Discussion | 3 | 04-04-2008 07:28 PM |
| 2.7 AJ head bolt torque & sequence | DaGr51 | Onan Generators | 0 | 09-03-2006 12:53 PM |
| Head bolt torque for onan15.OJC-18R?1282AA | mnjr | Onan Generators | 5 | 01-06-2006 07:35 AM |
| need to know bolt hole spacing for mounting herc 3hp "F" | Mac Leod | Antique Gas Engine Discussion | 3 | 07-19-2005 12:07 AM |
