Companion generator (Sears) no output
I have a companion generator(sears) model # 919-327210 6500 surge 5250 run. It was working ok. I...
this thread has 3 replies and has been viewed 2426 times
Old 10-09-2008, 10:10 PM
fcaramadre fcaramadre is offline
Default Companion generator (Sears) no output
I have a companion generator(sears) model # 919-327210 6500 surge 5250 run. It was working ok. I went to start it up one day and had no output. Well not really I have 1.5 vac across the 110 and 3.0 vac across the 220. I took the head apart and everything looked okay. It is a brushless setup. I see only one diode and one cap. I thought the diode was shorted and replaced it. I still have no output. The cap is a 35uf 370 vac and it tested ok with a meter. Any one have any ideas. What is used to excite the field? Is it the cap? How could I excite the field again. How about charging the cap will that work? I dont see any shorts in any of the windings but I am only guessing since I have no service manual. Any help would be great Thanks
Old 10-09-2008, 11:59 PM
Fred M. Fred M. is offline
Default Re: Companion generator (Sears) no output
The field depends on residual magnetism to start generating power. Flashing the field is normally only necessary when a generator has sat unused for a long time, like months or years.
If the diode actually was shorted, it might have managed to kill the residual magnetism. Either way, it wouldn't hurt to try flashing and see if it helps.
One way would be a quick "touch" of a 12 volt battery across one of the windings. That should be sufficient to get it started.
Fred
Old 10-10-2008, 08:58 AM
K D Redd K D Redd is offline
You said you checked the cap with a meter. What type of meter? If a normal VOM you may not have done a GOOD check. The ohm meter voltage may not have been high enough to realy check the cap. A cap like that is cheap enough I would replace for the BEST check.
Kent
Old 10-10-2008, 08:38 PM
Thank for your help but I get it going today. I made a reflasher using three 60 watt light bulbs ( I found the directions on line). It didn't want to work at first, but I reved up the motor and it started working. So far so good. Thanks for your help.
Aircraft Generator No Output! SteveL Generators & Motors General Discussion 18 01-09-2008 04:51 AM
6 Volt system Generator output Sky Antique Autos and Trucks 8 05-31-2007 02:05 AM
Question about generator output MReyes Kohler Generators 5 06-23-2005 12:17 AM
No output, AC generator Arthur Generators & Motors General Discussion 1 02-24-2005 12:12 PM
Exciting DC generator output to make A/c Dave Wright Generators & Motors General Discussion 10 07-29-2004 02:47 PM
