Monitor engine
How does the timeing mech work on a little Monitor PJ engine , I don't see much on mine, are they...
this thread has 7 replies and has been viewed 577 times
Old 04-12-2002, 09:11 PM
D.J. Baisch
Default Monitor engine
How does the timeing mech work on a little Monitor PJ engine , I don't see much on mine, are they batt and coil? thanks d.j.
Old 04-13-2002, 06:58 PM
BobJohnson
Default Re: Monitor engine
Hi My pump jack Monitor uses high tension model t coil and a wiper strap that wipes on pins on the camshaft to make the breaker for timing.Works well.
Old 04-13-2002, 08:26 PM
Joe Morris
Some Monitors used buzz coil , some used a Wico E.K. magneto. the majority I have seen were buzz coil ignition.
Old 04-14-2002, 08:04 PM
D.J. Baisch
Are there tags on those little Monitors?
Old 04-14-2002, 09:54 PM
Patrick M Livingstone
And all the Monitors in Oz seem to have magnetos on them
Patrick's Old Engines
Old 04-15-2002, 12:25 AM
Joe Steele
Tag is usually on top of the gas tank. I will try to get the info that I promised out to you soon.
Old 04-17-2002, 07:10 AM
Bud Bordelon
Can the age of a Monitor be determined by how they are built? My monitor has a lubricator,does not have a dip stick to check the oil or a guard on the gears and I don't have pins to trip the buzz coil, I have a cam with lobes. The serial number on the cylinder shows it built in 1937. I have seen other Monitors with lower serial numbers that have all the above mentioned items Can anyone shed some light on this?
Old 04-17-2002, 05:54 PM
robert atwell
the monitor i have has the timing pins sticking out of the small gear bob
Monitor Engine Bob E Antique Gas Engine Discussion 0 11-12-2007 08:39 PM
Monitor engine age George Robinson Antique Engine Archives 2 10-21-2003 06:44 AM
Monitor engine M. Smith Antique Engine Archives 9 09-30-2003 11:06 PM
Monitor 7Hp engine Kelly Barnett Antique Engine Archives 1 06-28-2003 09:21 PM
Monitor Engine Ken Antique Engine Archives 0 04-09-2000 01:20 AM
