Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Jacobsen Snow Jet
this thread has 6 replies and has been viewed 4708 times
Old 10-22-2008, 05:56:58 PM
Bunky Bunky is offline
Default Jacobsen Snow Jet
I was given this old Jacobsen Snow jet from a Friend, Does anyone have any information on this unit ???
Date of Manuafture etc...
Old 10-24-2008, 06:00:11 PM
Exclamation Re: Jacobsen Snow jet
Probably built in the mid 1960s, it is a very good machine for its time. I still use mine. only drawback - exhaust fumes get to you after a while!
Old 10-31-2008, 10:17:05 PM
Question Re: Jacobsen Snow jet
Well I gave this Snowblower to my Dad today as a project and when he went to take the flywheel nut off it broke the crank..
Does anyone know what brand this engine is its 2 cycle..
Old 11-01-2008, 09:28:08 PM
myron wininger myron wininger is offline
Default Re: Jacobsen Snow Jet
When I brake off the end of the crank I drill the end and tap it for a bolt .
Myron
Old 09-10-2011, 08:56:38 PM
Fritz Maurer Fritz Maurer is offline
Default Re: Jacobsen Snow jet
The motor is a Jacobsen 321.Where did the crank break?
Old 09-12-2011, 12:25:12 AM
Exclamation Re: Jacobsen Snow Jet
I will check my DATA book, to see when it was built. I may have a crank for that engine, I wll have to root around the garage a bit. Did your dad break it at the end or by the bearing? If at the end, you can still set up the mag to see if you have spark. Let us know what you find.
Old 09-13-2011, 10:08:24 PM
S/N 52001 comes up as a generic number for the Sno Jet Snow Blowers. It does not come up in the manufacturing data in the manual I have. The 52002 S/N begins in 1964, the next lowerr number, a different sequence is dated 1963, so I believe your machine is in that range of time. As of the 1971 Data book I have, there were 3 different cranks used in the SNO JETs, and 2 were discontinued, the 3rd only in the later engines (53000 series), was still available. The Sno Jets were built until 1970. Does your engine have a data tag on it? If so, can you relay the numbers to me in a PM?
1970 Jacobsen Snow Jet 20" AndrewOneal Small Air Cooled Gasoline Engines 4 12-22-2008 01:18:52 AM
Jacobsen snow jet 20" AndrewOneal Small Air Cooled Gasoline Engines 1 06-22-2008 11:48:58 PM
Ice-Snow Car Jim Tremble Antique Gas Engine Discussion 20 02-21-2005 11:35:12 PM
no snow Roger Kirschenman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-01-2005 01:37:13 PM
SNOW PIX Larry A. Dalton Antique Engine Archives 13 12-02-2003 07:07:23 PM
