| Alternative Fuels An energy source alternative to using fossil fuels. Materials or substances that can be used as a fuel, other than conventional fuels. Waste oils, vegetable oils or animal fats, which can be used alone, or blended with fossil fuels. |
Black DieselI saw an ad today on Craig’s list about this and went to the address oiltofuel.com, but it is...this thread has 14 replies and has been viewed 5941 times
I saw an ad today on Craig’s list about this and went to the address oiltofuel.com, but it is selling plans for it and doesn’t give any real info. It talks of processing used oil to use as fuel. Has anyone read about this or doing this?
I work at a dealer, and run used trans fluid 60/40 in my 00 7.3l Ford, but can get almost an endless supply of clean used oil if this process works good.
havent heard from anyone, does anyone know of a process to use used engine oil to make fuel other than burning it straight?
I've heard of a sawmill in our area that used to mix it 50-50 in the summer time. Used it in their trucks and forklifts. They didn't do it in the winter time because it would separate. The key is clean oil.
Rick |
The Following User Says Thank You to Rick McKay:
I have experimented with it a little with older military diesel engines. I wouldn't have any idea how it would effect newer ones. Take old motor oil/trans fluid, filter it WELL, WELL, WELL, [ good filters at biodiesel kit suppliers ] then we ran it 20-1 [ 20 gal. new fuel to 1 gal filtered oil ] Seems like we got it up to 10-1 , later w/o problems. Also, added a little diesel fuel conditioner .New filters on engine a must!
Remember- do this at your own risk. |
I filter and run used trans oil at 50/50 % and sometimes more in the summer and 70/30% winter with no problems. A friend w/ a 96 7.3l runs 100% trans in the summer with no problem here in texas. I just wonder how bad engine oil would smoke or if it will burn well. The web site i saw talked as if you process it some,but im not sure.
I am a maintenance manager for an fairly large independent fleet. We produce about 2500 gallons of waste oil every month. The oil is picked up by a recycling company that refines the waste oil into diesel.
The fuel that is produced does not meet the Department of Transportation or EPA standards, but is adequate for marine use where regulations aren't so strict. |
The Following User Says Thank You to moh58:
Over at listerengine.com we have a forum dealing with used motor oil as a diesel substitute, lots of info on other fuel sources too ! Paul.
The real trick to using Used LubeOil as Diesel Fuel, is to Filter it clear down to 5 microns,as ANY Particulate Matter in the Used Oil will quickly erode your Injector Pump precision parts and your Injector Tips. You also need to run it thru a deAcidfier, to remove the Sulfuric Acid, OR, never use more than a 20:1 Ratio Mix, with regular diesel. If you don't do that, your Fuel System will be Acid Etched, fairly quickly, as ALL the Acid products of diesel combustion end up in the LubeOil.
Bruce in alaska
The Following User Says Thank You to BTPost:
What i use is used trans oil, so i dont think the acidity is so high, i do filter 3 times though to get clutch/band material out.
Although waste engine/trans oil can be re-refined and cracked to produce excellent diesel fuel, this is a complex industrial process and requires a large scale and very expensive installation. However, it is possible to produce "black diesel" as a substitute fuel for diesel engines, by deacidifying selected used engine/trans oils and blending with a proportion of kerosene to adjust the viscosity to 35 seconds Redwood No 1, then force filtering down BELOW 5 microns, to remove abrasive particles which would ruin any injection equipment. Such "fuel" is better confined to older, less sophisticated engines in which it will work ok if you are very careful with the processing, but I certainly would NOT recommend using it in your new BMW!!. Actually, kits for the process used to be available for use in some African countries.
Tricky Dickie |
The Following User Says Thank You to Richard Sturdy:
What you need to make "black diesel" is a centrifuge to remove the sludge and metal particles. www.simplecentrifuge.com It works good for cleaning almost any kind of oil. Veggie, transmission, motor, hydraulic, etc.
Blending used oil in fuel seems to work much better in precombustion type diesels. My 1HZ Toyota engine tolerates 20 or 30% filtered used engine oil very well, but several trials in my direct inject motors (Perkins etc.) have resulted in heavy buildup of carbon on nozzle tips after only a few hours run. Had to pull injectors and brush off carbon to clear the smoke cloud and restore performance. Just one guy's experience, but have heard the same from others. Regards, Combustor.
To Extract Diesel Fuel from Wast Engine oil and have it be safe for normal life of the diesel engine is to distill off the alkanes that is in the range of diesel leaving all of the dirty oil waste and the Paraffin, hydrocarbons that make the engine oil behind to turn in to grease and dispose of the rest no other form of burning waste engine oil in a diesel engine is safe for the Injectors and pump no matter how fine you filter it, just cause it runs dont mean its harmless to the components I have seen used Waste Oil Refinery Stills and hardware for about 10,000.00 and a small Homegrown for sale propane powered still kits for around 3,000.00 But this form does not meet EPA and other requirements as It still is high in sulfur and will contain hydrocarbons that are left from Gas engine combustion that distillates with the diesel from the waste oil.
For the record I run Waste engine oil through 3, 1.7 Micron filters @ from 500 psi to 1600 psi depending filter restriction and dump it in my tractors and truck @ 60% Diesel 30% Waste engine oil 10%Kerosene |
Sounds like it would be a lot better to burn the waste oil in the furnace and burn the furnace oil in the diesel!
Not to mention vegetable oil. Anyone tried a blend of WVO and WMO (Waste Motor Oil)? Definitely agree on the centrifuge. A gravity filter using tight paper towel rolls as the element should work well. |
If you have a Ford 7.3, you might be interested in Dino Fuel Alternatives kit for Fords to run Veggie Oil (and I think many other oils). www.dinofuelalternatives.com I have a kit on my 04 Excursion thru which I burn stright vegetable oil after I have filtered and settled it. The kit is expensive but it works very well in all climates. They have a forum so you could ask about hydraulic, motor oil, etc. Hope this helps.
| Diesel fuel in older diesel engines (bio-Diesel) | Andrew Mackey | Alternative Fuels | 2 | 04-18-2008 05:22 PM |
| 25 HP Black Bear | Tom Weatherford | Oil Field Engines | 1 | 04-17-2006 12:01 AM |
| Black Economy | Arney | Antique Engine Archives | 4 | 01-15-2002 08:55 PM |
| Black Fairbanks Z | Chase | Antique Engine Archives | 5 | 12-12-2001 10:06 AM |
| Black F-M Z | Stan Agacinski | Antique Engine Archives | 0 | 12-16-2000 01:23 PM |
