Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Bending cast aluminium
We have a cast aluminium steering wheel from a c1920 tractor which at some point in its life has...
this thread has 6 replies and has been viewed 1150 times
Old 10-27-2008, 05:46 AM
David Parfitt's Avatar
David Parfitt David Parfitt is online now
Default Bending cast aluminium
We have a cast aluminium steering wheel from a c1920 tractor which at some point in its life has become badly distorted, possibly due to the tractor rolling over. Does anyone know how to bend old cast aluminium like this, perhaps using combination of heat/pressure or other method? We have already cracked one of the spokes by applying gentle pressure and are wary of heating too strongly in case it just melts. Any help or advice would be much appreciated. It may be that we end up trying to have a new wheel cast, but the rim is hollow so might be quite involved.
Many thanks
David
www.steel-wheels.net
Old 10-27-2008, 07:42 AM
Default Re: Bending cast aluminium
Aluminum should be annealed before trying to straighten it. You can gauge the temperature by sooting it with an acetylene torch, no oxygen. Heat until the soot burns off. If it's bent bad you may have to straighten and anneal in several steps.
The Following User Says Thank You to J.B. Castagnos:
Old 11-02-2008, 05:31 PM
Many thanks for your help with this, J.B.
Best wishes
David
Old 11-03-2008, 06:41 PM
Wayne Timms Wayne Timms is offline
Hi David,
Not going against the advice from J.B. Castagnos.
With bending castings, the one thing I think I know is the metal is compressed on one side and slightly stretched on the other side.
The problem is in straightening, you will compress the metal which was slightly stretched but you probably won't stretch all the metal which was compressed. Which will cause tears or cracks.
The only advice I would give you is not to try to bend it when it is hot.
Regards,
Wayne
The Following User Says Thank You to Wayne Timms:
Old 11-04-2008, 10:38 AM
Thanks for your input Wayne, much appreciated.
Best wishes
David
Old 11-04-2008, 03:42 PM
Forrest A's Avatar
Here:
http://www.key-to-metals.com/Article139.htm
The Following User Says Thank You to Forrest A:
Old 11-04-2008, 10:48 PM
Unhappy Re: Bending cast aluminium
I'm not a betting man David but if were to make odds on you getting that wheel straightened they would be around Wheel 90/David 10.......
The Following User Says Thank You to Craig A:
Bending copper tubing DanR Smoke, Flames & Gas (Off Topic) 18 12-07-2007 02:54 PM
Bending cast iron Morganr Antique Gas Engine Discussion 9 09-21-2006 09:15 AM
Cleaning aluminium Matt Fretwell Machine Shop and Tool Talk 4 12-06-2004 08:22 AM
Help bending cast brass tag Steve Royster Antique Engine Archives 2 09-15-2001 10:15 PM
Bending Cast Iron NICK Antique Engine Archives 9 08-17-2000 07:10 PM
