| Antique Engine Archives All archived posts from 1999 to 2004 when SmokStak was on EnginAds. This is a read-only board. |
Reeves Serial No.I have a Reeves with a 4" bore x 6" stroke. What H.P. is it and where do I find the serial numbers?...this thread has 4 replies and has been viewed 323 times
I have a Reeves with a 4" bore x 6" stroke. What H.P. is it and where do I find the serial numbers? Did this engine come with a brass tag?
Thanks, Jerry Logan Downey, CA |
Hi Jerry,
A 4in.bore with a 6 in. stroke should be about 2 1/2 hp. at around 450 rpm.A Reeves may be rated more or less from that equation.I have no exact information on a Reeves,but that should get you in the ballpark. Ed Kinch |
Jerry, Your engine is a 2 HP. They made 1, 2,3 HP sizes but not 2 1/2. I have never found a serial no. anywhere on a Reeves other than the brass tag which mounted on the front of the hopper. The serial no. would range between 3000-6000. Let me know if I can be of any further help, I am just up the road from you about 150 miles. Check out my Web page on Reeves if interested. Mike
Reeves Pulley Co. |
Hi Mike,
Is the 2hp rating at 450 rpm? Ed Kinch |
Ed, the 2 HP rated speed was 525. 1 HP was 600; 3 HP was 460; 4 HP was 400; 6 HP was 380; 8 HP was 350 and 12 HP was 310. The flywheel diameter for the 2 HP is 18 1/2 inches. Mike
| Cameron Ranch 40 HP Reeves, 4-110 Cases, 1-30 Hp Rumely, 1-32 Hp Reeves and ? | Randy Kvill | Stationary Steam & Traction Engines | 11 | 02-01-2008 06:15 PM |
| reeves help | Steve Reiners | Antique Gas Engine Discussion | 1 | 05-24-2006 09:22 PM |
| Reeves Serial Number Location | MYaeger | Stationary Steam & Traction Engines | 7 | 02-09-2006 01:46 PM |
| 32 Reeves engine on 40 hp Reeves Boiler | Casemaker | Stationary Steam & Traction Engines | 38 | 01-20-2006 04:37 PM |
| Reeves Serial Numbers | Mike | Antique Engine Archives | 0 | 12-02-2001 12:38 AM |
