Homelite LR5500 Generator
this thread has 8 replies and has been viewed 6852 times
Old 11-18-2008, 04:27:55 PM
rpmseattle rpmseattle is offline
Default Homelite LR5500 Generator
Hello Folks ... 1st time user here. Having a problem and hoping someone out there can help me.
Trying to feed an American Standard-Comfort 80 gas furnace using a Homelite LR5500 generator.The furnace runs fine when on house power but shuts down when switch to generator. One other factor. House power is 120-volt, Gen power is 130-volt.
Does anyone have any ideas? Contacted an HVAC company and they thought that the higher voltage might be the cause. If this is true is there a way to adjust the voltage output of this generator.
Any help will be appreciated.
Rich
Old 11-18-2008, 06:06:45 PM
Don Smith
Default Re: Homelite LR5500 Generator
Voltage control is dependent on engine speed. Slow down the engine using the carburator linkage adjustment. Many of the Homelite generators will not handle the start current necessary to start and run electric motors. If you were to measure the generator voltage while trying to start the furnace motor it would tell a lot about the problem. Many generators of that breed will have the voltage output collapse when placed under the start load of a motor. Don
Old 11-18-2008, 06:27:04 PM
also be certain your frequency is right.
Old 11-18-2008, 06:47:25 PM
Mikey4026's Avatar
Mikey4026 Mikey4026 is offline
I have heard of issues running some furnaces with variable speed fan systems. It appears that the power is not clean enough for the electronics in the speed controller (too much electronic noise and voltage spikes). It may effect some without the variable speed control also.
Mikey
Old 11-19-2008, 08:41:14 AM
armandh armandh is offline
a lot of the electronic ignition units are subject to bonding problems. reverse the AC leads and they work.
furnace blowers that are brushless DC or other exotic controls may be very picky.
even a standard motor may need a fresh run cap to go on a generator.
Old 11-19-2008, 03:16:40 PM
Thank you all for the information.
I now have someplace to start checking.
Thanks again.
Rich
rpmseattle
Old 12-01-2008, 04:31:04 PM
Just an update to what I found out concerning the running of a gas furnace using the homelite L%55500 generator. This is also a problem with other generators.
We contacted the manufacture of the furnace. He sent us a fax that showed the installation of a 30mfd@370-volt Run Capacitor across the load side of the furnace. They show the connection just down stream from the door switch. Connect it between the hot and neutral wires.
These instructions were followed and the unit works perfectly.
Old 12-01-2008, 08:38:13 PM
I did not know the ignition system could be power factor sensitive. however it does not supprise me.
Old 12-01-2008, 08:40:57 PM
The capacitor would be an effective filter for high frequency noise and "hash" also.
Homelite Generator Old Chris Hammerbeck Generators & Motors General Discussion 8 02-25-2016 02:14:42 AM
Old Homelite Generator Karen Bunnell Generators & Motors General Discussion 12 10-12-2011 03:03:33 PM
Homelite Generator Bart Generators & Motors General Discussion 2 09-10-2008 09:22:01 PM
Need help with old Homelite generator EdM Generators & Motors General Discussion 2 06-26-2005 02:07:02 AM
Homelite XL Generator midnight Generators & Motors General Discussion 0 03-17-2004 08:30:20 AM
