Fuel Shutoff Leaking at Tank
Just noticed a leak on my Generac 5000W generator where the fuel shutoff is connected to the bottom...
this thread has 6 replies and has been viewed 1019 times
Old 11-18-2008, 05:44 PM
Waterlogged Waterlogged is offline
Default Fuel Shutoff Leaking at Tank
Just noticed a leak on my Generac 5000W generator where the fuel shutoff is connected to the bottom of the tank. The fitting is obviously loose and it looks like it needs to be tightened but I don't see any threads or other tightening mechanism. The shutoff is a screw in style unit. Am I blind or just stupid? Does anyone know how it attaches to the tank. Thanks for any help.
Old 11-18-2008, 07:07 PM
K D Redd K D Redd is offline
Default Re: Fuel Shutoff Leaking at Tank
If this is a plastic tank, many use a rubber grommet that is pushed into the tank and then the shut-off valve is pushed in the grommet Sten,s has them and you might find one the would work at a Snapper dealer.
Kent
Old 11-18-2008, 09:19 PM
Wayne Hansen Wayne Hansen is offline
If you have a metal tank you could try disconnecting the fuel line and turning the shutoff into the tank until it comes tight. Worked for me!
Old 11-18-2008, 11:02 PM
It's a plastic tank and appears to be a press fit grommet. I'm not impressed with the design and need to come up with a reasonably priced fix.
Old 11-19-2008, 04:22 PM
Fred M. Fred M. is offline
Can you tell exactly where it is leaking?
When power failed during a 2004 hurricane, I found that mine had a relatively slow leak around the valve lever. A temporary rag was tied around it, and the gas evaporated without dripping.
After the storm, a new grommet and valve were purchased. It was quite hard to remove the old ones, and then the new valve was difficult to press into the new grommet. If I were to do it again, I'd probably use some kind of lubrication.
If yours is loose, be sure it is pushed all the way in. As I recall, the valve has a shoulder that should be seated against the grommet.
Fred
Old 11-20-2008, 12:32 AM
I ordered a new grommet today. I'll give that a shot before any major surgery.
Old 11-27-2008, 07:12 PM
Yanked out the old grommet and shutoff, cut grommet off shutoff, put in new grommet, lubed up shutoff and pushed it in. Good as new. Thanks all.
Positive fuel safety shutoff? rtholl Onan Generators 6 10-12-2007 09:06 PM
McCormick 6hp about 1920s - Fuel Pump Leaking Tom Herd Antique Gas Engine Discussion 4 08-10-2006 05:49 PM
leaking 1.5 hp M fuel pump Tracy Schroeder Antique Engine Archives 9 06-27-2003 01:23 AM
Leaking Gas Tank Kevin Bandy Antique Engine Archives 10 06-08-2000 09:39 AM
Re: Leaking Gas Tank Vic Libby Antique Engine Archives 0 06-06-2000 08:47 PM
