Wisconsin Engines
Wisconsin carb rebuild
I have got a Wisconsin engine model TRA-10D with a zenith series 68-7 carb. I need a kit that...
this thread has 7 replies and has been viewed 3947 times
Old 11-28-2008, 04:13 PM
Horse Power at 511 Horse Power at 511 is offline
Default Wisconsin carb rebuild
I have got a Wisconsin engine model TRA-10D with a zenith series 68-7 carb. I need a kit that contains most if not all the gaskets, seals and o-rings, as well as the needles and seats. I have found these numbers in the engine manual as carb kits: C181-329, LQ39, LQ33 and K2130. I will have to decide wich one I need as they each come with a different assortment of parts.
Does anyone know of a source in the internet or a store that I could get one from?
Old 11-28-2008, 04:21 PM
CJBennett CJBennett is offline
Default Re: Wisconsin carb rebuild
You can get them from Stens (aftermarket company). The part number is 520-379. Just go to your local power equipment shop.
CJ
Old 11-28-2008, 10:36 PM
bstrucker bstrucker is offline
Images: 97
CJ,how is Stens price on those kits,I need one for an S8-D,they're about $30.00 from Wisconsin.
Old 11-29-2008, 08:26 AM
Dealer cost is $25. They list for double that. I'll give you the deal though. Let me know if you want one. The kit has everything!!!!
CJ
The Following User Says Thank You to CJBennett:
Old 07-12-2009, 07:00 AM
reddon reddon is offline
Question Re: Wisconsin carb rebuild
Same query - complete rebuild kit for Zenith 68-7 carb - where do I get it ? I have been unable to find it on Stens.
Old 07-12-2009, 03:59 PM
K D Redd K D Redd is offline
What do you mean by complete? If you mean including a new float, you are not going to get that, Try either STENS P/N 520-171 or 520-379.
Kent
The Following User Says Thank You to K D Redd:
Old 07-13-2009, 02:39 PM
I have been to two of my local lawn equipment dealers - neither does business with Stens, nor can they cross reference off Stens part number to get a rebuild kit for a Wisconsin 68-7 carburetor. Where do I get this kit, Stens or otherwise??
Old 07-15-2009, 10:59 PM
jamest jamest is offline
Try Mcdonald carb and Ignition. They have a web site and carry all kinds of kits. Bought one for a wisconsin tf. I seem to recall they were running about $30.00
The Following User Says Thank You to jamest:
Tilloston Carb rebuild Horse Power at 511 Small Air Cooled Gasoline Engines 3 08-01-2008 12:46 PM
Wisconsin ABN carb parts SMertz Wisconsin Engines 2 07-19-2008 04:59 PM
Wisconsin/Stromberg Carb Jerry Wisconsin Engines 8 06-27-2008 01:46 PM
carter n carb rebuild kit fbref5269 Antique Marine Engines and Outboard Motors 1 10-10-2007 12:04 AM
zc carb rebuild kits Ray Cardoza Antique Gas Engine Discussion 2 12-23-2005 04:47 PM
