HELP! I need a Briggs crankshaft
this thread has 20 replies and has been viewed 2540 times
Old 12-12-2008, 09:21:13 PM
Mike in CA Mike in CA is offline
Default HELP! I need a Briggs crankshaft
I am almost finished with the restoration of a briggs NP but I have run into a big problem. I need a new crankshaft, the one I have is scored real bad on the connecting rod journal. The connecting rod is also in bad shape but they can be found on ebay. The piston is not in the best shape but it is still useable.
Old 12-12-2008, 09:58:32 PM
Butch Yowell's Avatar
Butch Yowell Butch Yowell is offline
Default Re: HELP! I need a Briggs crankshaft
The N-NP-NR-NS-U-6-6H-6S are the same engines and cranks and rods are interchangeble. The differences are which type of starter you have, and what the PTO is doing.
Butch
Old 12-12-2008, 10:36:41 PM
My NP has a ball bearing on the pto side. There is no keyway on the pto end and the end of the crankshaft is threaded. The type number is 306598
Old 12-12-2008, 11:13:38 PM
bart price bart price is offline
mike your crank is a scooter aplication usually if its threaded thats for the clutch to screw on
The Following User Says Thank You to bart price For This Post:
Old 12-13-2008, 02:27:22 AM
Jester Jester is offline
Checking my IPL for the model N, I found the crankshaft for your type no. listed as p/n 26886. This crank was used on 19 other type nos. for the N and 23 type nos. for the model 6. Additionally, p/n 26782, used in the model 8, will interchange with your crank. The problem will be finding one since both of these have been discontinued for years, and the chance of finding a parts engine with a crank in better shape than yours will be difficult. Another alternative might be to have your crank carefully checked to see if your crankpin can be turned down .020 undersize. Briggs made a rod for this kind of repair, p/n 292510. These do show up now and again on eBay.
The Following User Says Thank You to Jester For This Post:
Old 12-13-2008, 10:54:07 AM
Skip Landis Skip Landis is offline
check with john smith, briggsnut he has lots of nos briggs parts
Old 12-13-2008, 12:08:06 PM
Mac Leod Mac Leod is offline
what about welding and regrinding?
Old 12-13-2008, 02:49:28 PM
There is not a machine shop in town that can weld and grind a crankshaft. The closest shop is 40-50 miles away.
Old 12-13-2008, 07:23:45 PM
grega's Avatar
grega grega is offline
Images: 106
no the NR uses a different crank shafr that has the gear reduction gear splined into it.
-Greg
Old 12-13-2008, 07:27:41 PM
grega's Avatar
Images: 106
oh also i might have one i have a couple I - 5 - WI - WM - WMB cranks i might have a spare N crank now if its front kick start thats a different storie if i do have one i wouldnt be able to get it out until after christmas
-Greg
Old 12-13-2008, 10:33:51 PM
Beanscoot Beanscoot is offline
Default Briggs crankshaft
When I was a machinist apprentice I had a 6B crank turned down, plated up with nickel and ground to standard size, at the large establishment where I worked.
Perhaps you could find a place that could do this service. Does it really matter if the shop is 40 or more miles away? Couldn't you just mail the crank, after talking to the shop on the phone to insure you are comfortable with it?
Old 12-14-2008, 12:24:12 AM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Images: 119
This guy dose cranks. His phone number is on his auctions on ebay. Here is one of his auctions. Item number: 120347810338 Real helpful guy. Good luck!
Dennis
Old 12-14-2008, 12:47:10 PM
Dan Baalman Dan Baalman is offline
Mike I bought a bunch of Briggs and Maytag parts and engines form a guy a while back. I think there are a couple of loose cranks in the boxes. It is down at the farm and I would have to get there to look. If you don't find one you would be welcome to one if there is one. Pay the postage and I will send it.
The Following User Says Thank You to Dan Baalman For This Post:
Old 12-14-2008, 06:47:34 PM
@Beanscoot
I could drive the 50 miles to the machine shop that is not a problem I would have prefered to have the work done it town but that is not going to happen.
@Dan Baalman
Thank you for the offer. Let me know if you need pictures of the crankshaft I have.
Old 12-14-2008, 08:31:03 PM
Things have changed somewhat, now I need the ball bearing that is on the PTO side of the crankshaft on the NP. I am not sure if the old one could be re used or not. Are they still Availble?
Old 12-14-2008, 10:53:58 PM
Default Ball Bearing
Although I'm not familiar with that particular bearing, there's a good chance it is a standard bearing. Measure it up with vernier calipers (OD, ID and thickness). A lot of bearings, even old ones, are metric sizes so check for both standard and metric dimensions.
I would first clean the old bearing thoroughly in solvent though and see if it's usable. It doesn't have to be perfect for an engine that won't see a lot of hours. It just can't be really sloppy.
Old 12-14-2008, 11:17:05 PM
Briggs still lists that bearing. Part no. 99158. Lists for $9.95.
Old 12-14-2008, 11:51:08 PM
Is the rear seal still availble? There is a number on the old seal #50212.
Old 12-15-2008, 03:53:14 AM
Mike pictures would help I might get to the pile early this week.
Old 12-15-2008, 04:29:57 AM
Here is the crankshaft in question.
crankshaft id Retiree Small Air Cooled Gasoline Engines 2 12-04-2005 09:34:04 AM
IHC M 1 1/2 hp crankshaft Robert Johnson Antique Engine Archives 8 01-29-2004 04:35:05 PM
crankshaft gatweedie Antique Engine Archives 1 01-25-2004 08:57:48 PM
BIG crankshaft Craig Anderson Antique Engine Archives 5 11-24-2003 08:32:30 PM
Briggs & Stratton Crankshaft Brad Rodenkirch Antique Engine Archives 1 06-01-2000 11:07:16 PM
