Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Toy Steam Engines and Motors
Availability of Bing belts and parts . . .
My thanks to Jeff and Casey. My Dad's old steam toy is a Bing. Does anyone know of...
this thread has 4 replies and has been viewed 631 times
Old 12-21-2008, 04:17 PM
Paula G Paula G is offline
Default Availability of Bing belts and parts . . .
My thanks to Jeff and Casey. My Dad's old steam toy is a Bing. Does anyone know of a good source for replacement belts? Also, is there an EASY way to fill the small triple wick burner?? I have a can marked 'Alcohol' that's very old. The fluid is clear . . . Any idea what type of fuel this is and where it can be purchased?? Thank you all!! --Paula
Old 12-21-2008, 04:36 PM
Mike Monnier's Avatar
Default Re: Availability of Bing belts and parts . . .
Denatured alcohol, available at any decent hardware or home improvement store. Usually found in the same section as paint thinner.
I'll defer to the experts on the belt. I believe they are typically a "spring" with the ends hooked together to form a belt.
The Following User Says Thank You to Mike Monnier:
Old 12-21-2008, 06:39 PM
tony i tony i is offline
In england we can buy spare belts for both wilesco and mamod Another source that I have used, if you can find them, is to take them from old engine oil seals
The Following User Says Thank You to tony i:
Old 12-21-2008, 11:50 PM
laknox laknox is offline
Hi Paula. One thing you can do for "belts" is to use 2.0 or 2.5 mm rubber o-ring material cut to length and super-glued together. Not sure about flat-belt material. For filling your burner, you might look for a Nalgene bottle with a needle tube to fill it.
Lyle
The Following User Says Thank You to laknox:
Old 12-24-2008, 04:02 PM
CaseyJoeS. CaseyJoeS. is offline
Location: McPherson, Kansas for college. Delmar, Maryland is home
The burner you may take out a wick to fill it, and then place the wick back in the burner when it is filled. Dont fill it too much, otherwise when you light it and it heats up things will expand and you'll end up with a bit more flame than you'd like!!
Just call up Jensen at 1-800-525-5245 and you can order the spring type belts, and you can get them in 4.5" or 9" lengths. Since they have hooks on the ends you can add as many as you like together to get a certain length, or they can also be stretched slightly so they fit. Jensen is taking a holiday and wont be back at the factory till January 2nd.
Check out their website www.JensenSteamEngines.com
The Following User Says Thank You to CaseyJoeS.:
Bing Gallogly Auction Roger Eldred Auctions of Engines, Tractors and Old Iron 2 08-25-2008 10:43 AM
Naptha availability Elden DuRand Alternative Fuels 41 01-11-2008 09:02 AM
waterloo boy parts availability Jordan Antique Gas Engine Discussion 4 10-27-2006 02:39 PM
Making flat belts from conveyer belts Ihorse Antique Gas Engine Discussion 7 12-03-2005 11:01 PM
Decal Availability? ihorse Antique Engine Archives 2 06-09-2004 10:33 PM
