Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Oddball
Heres a odd ball engine I have just purchased. Any clues Thanks Kevin K 1-848-992-1764 ...
this thread has 3 replies and has been viewed 864 times
Old 12-27-2008, 10:44 AM
Kevin Kusel Kevin Kusel is offline
Banner Sponsor
Default Oddball
1-848-992-1764 BIGFLYWHEEL@AOL.COM
ID:	45660   Click image for larger version
Old 12-29-2008, 09:52 AM
Daniel Dorece's Avatar
Daniel Dorece Daniel Dorece is offline
Default Re: Oddball
What does it say on the tag? The flywheels and crank look like 1 HP IHC and since it is a throttler there might be some relationship.
Iron Wolf
Old 12-30-2008, 01:00 PM
Robert Haus Robert Haus is offline
Default Re: Oddball
Is that a knife switch in the high-tension lead for the spark plug???? OUCH!! I'd do away with that in a hurry.......set it up to diconnect the primary that is feeding the buzz coil rather than trying to disconnect the hot lead (besides a shock, you don't want to run a coil or mag without a plug or other path to ground...it is bad for the windings.) But I disgress....
Old 01-01-2009, 10:32 PM
Jordan's Avatar
Jordan Jordan is offline
Default Re: Oddball
hi kevin,
while checking enginads i came across this one, it looks extremely similar to yours.
here is the link:
http://www.enginads.com/classifieds/...ct/17362/cat/2
hope this helps some,
happy new year
jordan
oddball screws on carby Mac Leod Antique Gas Engine Discussion 2 05-20-2007 12:46 PM
Oddball Stover Ct-2 ???? David Babcock Antique Gas Engine Discussion 1 03-11-2007 10:55 PM
Bates/Joliet Single Track Oddball berkut1965 Antique Tractors - Old Iron Lugs, Cleats and Tracks 7 02-07-2007 08:49 PM
obscure and oddball engines. info wanted JBoogie Stationary Steam & Traction Engines 11 10-06-2005 05:58 PM
Oddball wizard Ihorse Antique Gas Engine Discussion 0 04-20-2005 09:31 PM
