Need advice on removal of gen rotor from PTO shaft
this thread has 10 replies and has been viewed 5106 times
Old 12-30-2008, 10:31:10 PM
mbdittmar mbdittmar is offline
Default Need advice on removal of gen rotor from PTO shaft
I have a Briggs and stratton engine which was formerly running an agtronic generator head. The gen head turned out to be toast, but the engine is good, so I wanted to remove the gen head. I have everything off except the gen rotor, and I'm not sure how it is supposed to come off ( see attached pics ) off the PTO shaft. It almost looks like it is pushed on the shaft and held in place internal to the engine, but I'm not sure. I'd rather not remove the side plate if I don't have to! This is a model 190432 type 5130, and is a flange mount ball bearing PTO ( no gear reduction ) BTW, Those gray things are just remnants of a fan and are attached to the rotor coil, they don't impact anything. Anybody come across something like this who could offer me some advice ? Thanks !
Old 12-30-2008, 11:26:49 PM
Gailey Henderson Gailey Henderson is offline
Default Re: Need advice on removal of gen rotor from PTO shaft
A long bolt through the rotor the engine shaft is tapered
Old 12-30-2008, 11:40:19 PM
Mikey4026's Avatar
Mikey4026 Mikey4026 is offline
Some rotors have threads on the inside of that bolt hole that Gailey mentioned, you can thread in a legenth of all thread to push the rotor off the taper.
How many horses do you have there? I have a good 4400 watt end.
Mikey
Old 12-30-2008, 11:58:43 PM
Yes, there was a long bolt which went through the rotor shaft, which I removed. I'm guessing it may take some force to get it off of the taper? I tried to pull the rotor off by prying with a crowbar but no luck. I'm not sure how far the threads extend back in the shaft, but I'll give the all thread a try.
BTW, it is an 8 hp motor.
Old 12-31-2008, 01:25:20 AM
Well, I tried taking the original bolt and adding a bunch of washers underneath it, so the bolt should act as a puller. If I understand correctly the PTO shaft is threaded, and the rotor is just held on with this long bolt ? So, really tightening down on the bolt with added washers should have pulled the rotor off, I think. Is that right ? Unfortunately this didn't work.
If this is correct, this rotor must be frozen tight onto the shaft.
Old 12-31-2008, 02:33:57 AM
half-fast half-fast is offline
The rotor is a friction fit on a taper on the end of the crankshaft PTO end. Any pressure from tightening a through bolt in the rotor will force the rotor tighter on the crank. What I do is #1. Take a tap and tap threads inside the bore through the center of the rotor about 3/4 to 1 inch. #2. Build a push rod to extend through the center of the rotor against the crank so that it is about 1/2 to 3/4 inch deep in the rotor. #3. Turn a cap screw into the thread against the push rod to pull the rotor. NOTE: I turn a pilot on the end of the push rod that goes through the threads in the crank to protect the crank. Also the diameter of the push rod should be ideally as large as possible and still able to slip through the rotor or it will bend and crush due to the length. It requires tremendous pressure on some of these to remove. Where you have pulled the rotor even tighter on this one it will probably be tough. This is similar to pulling a snowmobile clutch. Good luck.
Happy New Year!! Denny
The Following User Says Thank You to half-fast For This Post:
Old 12-31-2008, 02:50:56 AM
Thanks, I'll try this method out....it makes a lot of sense.
Not sure what I was thinking !
Old 12-31-2008, 04:15:10 AM
armandh armandh is offline
like ball joints and tie rod ends
once the removal preasure is on
a good smack to the side of the taper joint will shock it loose
Old 12-31-2008, 09:48:40 AM
K D Redd K D Redd is offline
I thread the end of the rotor's hollow shaft with 1/8" NPT, install a grease zert. Then pressurize grease. The rotor may not loosen immediately but will come loos e in a day or so. The reaseon I do it this way is I can not bring myself to subject the rotor to possible damage by hitting it with even a rubber hammer.
Kent
Old 12-31-2008, 01:14:57 PM
Kent
Hi- I had a much older Pincor unit that smacking, etc, would NOT free. I tried the grease gun trick and it worked. I have since used the trick on another stubborn unit. If your's has a taper fit design, it might work for you.
Check this thread out. You may notice that I was slow to hear the music.
http://www.smokstak.com/forum/showth...ghlight=pincor
Old 01-22-2009, 06:35:04 PM
Smile Re: Need advice on removal of gen rotor from PTO shaft
Finally got around to working on this again. I used the push-rod and threaded rotor shaft technique mentioned above. Rotor popped off pretty easily ! Thanks for all the great tips !!!
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft Jordan Garden Tractors / Mowers / Scooters 18 06-16-2009 03:49:11 PM
How to pull rotor from mag? Steve Jags Magnetos, Ignition Coils and Spark Plugs 2 12-08-2007 02:29:06 PM
X Rumely Steering Shaft Removal Problem?? Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-07-2007 12:52:59 AM
onan rotor removal R VanDevere Onan Generators 2 10-24-2005 03:11:22 AM
Coleman Rotor Arthur Generators & Motors General Discussion 3 09-28-2004 08:33:10 PM
