Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Un known Gov assy
I found this gov assy in an old pump house years ago and never knew what engine it came from.I...
this thread has 0 replies and has been viewed 399 times
Old 01-04-2009, 09:56 AM
Todd Ryker Todd Ryker is offline
Default Un known Gov assy
I found this gov assy in an old pump house years ago and never knew what engine it came from.I believe its an early engine by the way it bolts to the flywheel (see picts) The sliding collar has 2 holes to hook up the control arm. The long studs are for the gov springs to hook to the other 2 are rusted off.I would guess its in the 2 to 3hp size engine.
I hope someone can identify it for me Thanks Todd
ID:	46091   Click image for larger version
ID:	46092   Click image for larger version
Webster mag, Which way is right armature assy rustaholic Magnetos, Ignition Coils and Spark Plugs 0 10-01-2006 12:15 PM
Fairbanks cam/governor assy. Sky Antique Gas Engine Discussion 7 05-15-2005 02:30 AM
IHC. small air cooled fan assy. Larry Hughes Antique Gas Engine Discussion 1 04-29-2005 10:16 PM
Need new/different cylinder assy. David Showerman Antique Engine Archives 1 08-22-2000 11:51 AM
