Sears 5k 5803189-1
Help A friend tried to install a new outlet in my generator. I cant find a wiriing diagram...
this thread has 3 replies and has been viewed 453 times
Old 01-06-2009, 01:10 AM
charbo01 charbo01 is offline
Default Sears 5k 5803189-1
Help A friend tried to install a new outlet in my generator. I cant find a wiriing diagram anywere. The wires are all number taged Just dont know were they go. Thank You
Old 01-06-2009, 02:24 PM
Fred M. Fred M. is offline
Default Re: Sears 5k 5803189-1
Charbo-
Go to the sears web site and click on PartsDirect. Enter 58031891 in the model number box. You will then be able to select several sub-assemblies of your generator. It is possible that one of the illustrations has connection data.
The 580 in your model number refers to Generac, which is now owned by Briggs & Stratton. Parts listed at the Sears web site may not be available from Sears, but the part numbers are Generac, and you should be able to obtain them from other sources. (Sometimes you have to add "GS" at the end of the number.)
Fred
The Following User Says Thank You to Fred M.:
Old 01-06-2009, 11:56 PM
My friend I got no help from sears,generac or briggs and stratton. I dont know were wire number 22 Hooks up Thank you for your responce
Charlie
Old 01-07-2009, 11:02 PM
airhead airhead is offline
Charbo.
The #22 wire is one of the power wires that come from your stator. If it is a single voltage type power winding you will have one marked 22 which is red and #11 which should be blue. If its a dual voltage you'll also have a lead marked #44 which should be gray.
Hope this helps Good Luck Jim
Stover or Sears Brickman Antique Gas Engine Discussion 3 01-07-2008 08:56 PM
Sears engine ID The Engine Doctor Antique Engine Archives 2 05-22-2004 11:25 AM
Sears Tag on a Briggs? Dan Bogart Antique Engine Archives 3 06-14-2003 04:34 AM
Sears Gen. Guy (GUS) Simms Generators & Motors General Discussion 1 01-27-2001 09:48 AM
Sears Model K Don Antique Engine Archives 0 08-08-1999 10:54 PM
