Welding Shop
Miller TBolt 225 AC Plug
this thread has 3 replies and has been viewed 4943 times
Old 01-08-2009, 12:08:24 AM
evilleshepherd evilleshepherd is offline
Default Miller TBolt 225 AC Plug
Hi all, I bought an older Miller Thunderbolt 225 buzz box at a farm auction for $70. It's a style (U-1-A-2). I can't find a serial or model number. It sets horizontally with the amp adjust. crank on the front instead of the top. My garage 220V service is fed from the house with only 12Ga. wire from (2) 20A fuses and I seriously doubt this can carry the welder load. Just inside the walkout basement door at the house I have a 50A stove recepticle. I'm pretty sure I can plug it in there if I swap out the the plug on the welder to a 50A plug but I wanted you guys to weigh in on this? Also, does anyone have any idea what model this is and how old it may be by the 'type' number 'U-1-A-2'? Thanks for any input.
Old 01-08-2009, 11:34:01 AM
Dave R Dave R is offline
Default Re: Miller TBolt 225 AC Plug
The number 12 20 amp wireing definately wont be big enough. If the stove outlet is wired and fused for 50 amps at 230 volts thaen that ought to work fine.
Dave R
Old 01-31-2009, 06:08:52 PM
Holland501 Holland501 is offline
I agree with DaveR about the electrical stuff, but I would change out the outlet to match the welder and leave the plug on the machine alone. If the outlet is still in use for a stove, make a short adaptor cord. Anytime you start cutting up the input cord, you could raise the resistance, causing the connection to heat up. Just my $.02
Old 02-01-2009, 10:02:40 AM
Nitesky Nitesky is offline
I have an AC/DC Canox Sparkler (Thunderbolt in red) with the amp adjust on top. You will like yours a lot better. Less sh** gets in from grinding.
Mine has never tripped the 40A breaker it is powered by and I have used it cranked to the limit in both ranges on occasion.
Would be good to change or add to the plug. The next welder would automatically fit
Replacement Spark Plug for Maytag Uprights?? Modern Plug? enginesilo Maytag Engine Collectibles 3 08-31-2008 01:21:57 AM
Miller 351 jnorton Welding Shop 3 06-29-2007 10:40:13 PM
miller welder sparkplug54 Welding Shop 0 12-03-2006 06:24:02 PM
ed miller auction harold burkholder Antique Engine Archives 5 10-21-2004 04:10:46 PM
onan/miller Robert Srour Onan Generators 1 09-16-2003 11:35:29 PM
