CONTINENTAL Red Seal 4 cylinder flat head engine
this thread has 6 replies and has been viewed 17858 times
Old 01-10-2009, 12:50:44 PM
treecutter00 treecutter00 is offline
Default CONTINENTAL Red Seal 4 cylinder flat head engine
i got an old lincoln arc welder model 200SA it runs on a CONTINENTAL Red Seal 4 cylinder flat head engine anyone know where to get parts to repair a governor. we contacted a lincoln dealer and he said that the welder was built in the 30's..it's almost the same engine that u would find in an 8N ford tractor the only differance i saw was that the ford had a distributor and the welder has a magneto ignition.any info on the welder would be great!!!!thanx
Old 01-10-2009, 01:43:09 PM
Default Re: CONTINENTAL Red Seal 4 cylinder flat head engine
Does the governor have any ID info on it?? I think Cont used different suppliers; if you can ID the gov it'll be a big help.
The engine should have a tag on it (Cont didn't always put them in easy to spot places) giving the engine model and serial #.
Once you ID the engine (assuming gov parts are no longer available thru local sources) contact montesequipment.com, dealers in obsolete Cont parts; I don't know if they stock gov parts, but should be able to at least ID the gov in your installation, and maybe suggest places to try.
Try running the archives here; there's been previous posts about Cont gov's, and a parts source may be mentioned, or an alternative hookup. Good luck.
The Following User Says Thank You to Bud Tierney For This Post:
Old 01-10-2009, 03:26:27 PM
wydiver wydiver is offline
I have a 1969 army welder with the flathead 6 in it (continental) and It has a slick magneto on it. the military used aircraft mags for there stuff. Try parossmachinery.com they are in dallas and seem to know every thing about continentals.
good luck
Bryon
The Following User Says Thank You to wydiver For This Post:
Old 01-10-2009, 06:02:28 PM
Most likely it is a version of the F-400 series engines. Look on the block for some casting numbers. There are at least 3 different types of mechanical governors that can be found on their engines. Do you have pictures of the governor?
Old 01-10-2009, 11:00:01 PM
FarmallJeff FarmallJeff is offline
Hi if you get some numbers i have a good engine out of a compressor ill check and see what the Model # is and its complete the compressor let go andi kept the rest.
JEFF
Old 01-23-2009, 01:37:54 PM
ushudsons ushudsons is offline
sir check with weldmart.com
Old 01-24-2009, 02:55:51 AM
Dempster Dempster is offline
Lincoln welder and some engine downloads are at this link....
http://content.lincolnelectric.com/p...m/obsomenu.pdf
Manuals for Continental at Wisconsin Motors site ....
http://www.wisconsinmotors.com/partcatalog-ex.html
Did you try Montes Equipment ?
http://www.montesequipment.com/
V12 flat head Ford engine Phillip Hutchinson Antique Autos and Trucks 30 03-19-2015 12:25:10 PM
Continental Red Seal Power Unit Engine Ben Dixon Antique Gas Engine Discussion 13 01-28-2012 01:35:05 PM
Continental Red seal Byron Roberts Antique Autos and Trucks 16 11-30-2011 07:47:04 PM
Continental Red Seal FarmSC Antique Gas Engine Discussion 3 10-28-2008 09:55:46 PM
Continental Red Seal Power Unit DougM Antique Gas Engine Discussion 18 04-13-2008 10:52:23 PM
