Transfer switch
Anybody know where I could find an old Model ETUMP-100-3/11 I really like the idea of this thing....
this thread has 6 replies and has been viewed 1460 times
Old 01-12-2009, 08:54 PM
milmaint milmaint is offline
Default Transfer switch
I really like the idea of this thing. Plugs in, between utlity meter and meter socket.
http://www.bdub.net/manuals/Onan/LoadTransferSwitch.pdf
Old 01-12-2009, 09:23 PM
VaughnSimon VaughnSimon is offline
Default Re: Transfer switch
Some power companies will sell you a transfer switch adapter that simply plugs between your meter and its existing socket. You plug your generator into the adapter.
http://www.fpl.com/energy_services/o...tml?WT.ac=ES01
Vaughn
Old 01-14-2009, 01:55 PM
Fred M. Fred M. is offline
Vaughn-
I called the FPL number and found that their "One Plug" switch was made by Generlink (.com).
The FPL web site indicated that the program would eventually be expanded outside the Miami area, but it seems that is not going to happen. They said that when the existing supply has been installed, the program will end. I wonder if that is because of a large number of problems encountered?
It may be possible to have a local licensed electrician install one of the units. The Generlink web site has an order form you can download, but there is no mention of price.
Fred
Old 01-14-2009, 01:58 PM
Isaac-1 Isaac-1 is offline
All of the modern versions of this that I have seen seem to be limited to 50 amps on the generator side.
Ike
Old 01-14-2009, 03:21 PM
More likely because the world did not exactly beat down their door clamoring to have them installed. Most folks just go to Home Depot and buy a generator, without a lot of thought about how they will connect it, or fuel it, or...
Vaughn
Old 01-14-2009, 09:43 PM
The model I was talking about is a 100 amps on the gen side and 200 on the service. Would really like to find on of these.
Old 01-15-2009, 12:16 AM
EricWood's Avatar
EricWood EricWood is offline
Milmaint,
It will probably be a pretty rare find, if you can find one of those old ETU's at all.
I don't think you'll find anything similar today (Generlink or otherwise) with a 100 amp generator rating. With the quality of todays meter box arrangements, I would hate to see one of those devices hanging there with a 100 amp cord's dead weight hanging off of it.
A manual double throw switch that is positioned between the meter and your service panel is probably about the most economical route to go, for total house back up potential or load managing by breaker selection in your existing panel.
eric
Transfer Switch Sean W Onan Generators 2 07-04-2009 12:44 PM
Transfer Switch FisherManJohn Generators & Motors General Discussion 28 07-04-2009 12:33 PM
DJC transfer switch? DieselCJ Onan Generators 8 07-04-2009 12:16 PM
Transfer switch help d6btex Generators & Motors General Discussion 9 10-14-2007 07:49 AM
Transfer switch Sean W Onan Generators 3 01-04-2006 08:43 PM
