Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Unidentified Engines
Gold mine motor
This motor came from an old gold mine on the Fraser River BC. The cyclinder is 4.5 ", the stroke...
this thread has 13 replies and has been viewed 1365 times
Old 01-14-2009, 12:12 AM
L Kirk L Kirk is offline
Default Gold mine motor
This motor came from an old gold mine on the Fraser River BC. The cyclinder is 4.5 ", the stroke approx 9", flywheels are 25" in diameter, the head gasket looks to be made out of lead. Id tag is missing and it was on the left hand side looking from the had.lkirk@telus.net
ID:	46621   Click image for larger version
The Following User Says Thank You to L Kirk:
Old 01-14-2009, 12:24 AM
bruce burgess bruce burgess is offline
Default Re: Gold mine motor
wow
excellent find..looks like a 1.5 hp T Eaton, with a few parts and some de-rusting you could get er going one day.....
i scoure mine sites every chance i can havent found a engine yet.
bruce
The Following User Says Thank You to bruce burgess:
Old 01-14-2009, 12:32 AM
found a picture of a Majestic on the internet and it looks very close..any idea where i could get parts Larry
Old 01-14-2009, 12:36 AM
the engine is a waterloo, but was tagged by 20 or 30 other secondary dealers.
parts are avalible here or ebay im sure someone will comment further.
bruce
Old 01-14-2009, 01:20 AM
larry
im not sure about bore and stroke spec you gave as i have no data to refer to but after thinking about it i belive its a 4hp its hard to tell from the pic on the size, but the head studs make me think its larger than what i said before.
bruce
Old 01-14-2009, 01:37 AM
spfx_dude spfx_dude is offline
Yep, for sure this is a waterloo boy... likely sold by T Eaton. It still has evidence of the red paint and the hopper is unmistakeable. Did you find the caps for the crank shaft connecting rod? The horse power should be stamped there. I likely have some parts for this one. Check out my gallery at
http://www.engineutopia.com/gallery/...neengines.html
if you scroll down to the waterlooboy there are pictures.
The Following User Says Thank You to spfx_dude:
Old 01-14-2009, 01:39 AM
On second look, I am not sure why there is a groove in the flywheel. This is an interesting one.
Old 01-14-2009, 03:14 AM
GRookus GRookus is offline
i had an eng. looked like that one, and it was tagged john smythe
The Following User Says Thank You to GRookus:
Old 01-14-2009, 09:54 AM
Bill Wehrman Bill Wehrman is offline
Defective Email Address
Yeah, it's Waterloo built, not a Waterloo Boy. I would also guess Eaton or Smyth, could be one of several other red ones. Would also guess that someone cut a groove in the flywheel for a V-belt. 4 1/2 X 9 would be a 4 or 5hp depending on who slapped the tag on it.
The Following User Says Thank You to Bill Wehrman:
Old 01-14-2009, 12:19 PM
Skip Landis Skip Landis is offline
Card Sponsor
i have a 2 horse reeves that came from a mine. it also has a vee belt groove machined in the flywheel. maybe something they did to mine engines? skip
The Following User Says Thank You to Skip Landis:
Old 01-15-2009, 11:22 PM
not sure if my last message contained my private email address if not, please contact me at lkirk@telus.net the l is for Larry, not a one...1 Larry kirk
Old 01-15-2009, 11:24 PM
not sure if my last email to you contained my email address
lkirk@telus.net the l is for Larry and is not a 1 one...
Larry Kirk
Old 01-17-2009, 12:14 AM
Nathan K. Nathan K. is offline
Hi,
Your engine looks just like my 4 or 5HP T.Eaton (waterloo made). Do you have any of the missing parts? you may want to search a large area where it was found, also do you take any treasure as found photos?!. I ended up making a lot of parts for mine including a new pushrod with the roller so if you need parts made maybe something can be worked out? Nathan.
The Following User Says Thank You to Nathan K.:
Old 02-07-2009, 02:36 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Your engine fits the dimensions of a 4-1/2hp Waterloo built T. Eaton Co. engine. Check for the serial number stamped on the end of the crankshaft:
http://buzzcoil.brinkster.net/eaton/page103.html
Colorado Gold Mine-Steam mank10 Stationary Steam & Traction Engines 2 03-09-2008 11:24 AM
Nelson, Nevada gold and silver mine trip KeithW Antique Gas Engine Discussion 4 12-27-2005 01:49 PM
Is it just mine? David L. Showerman Antique Engine Archives 6 01-17-2003 10:54 AM
Mystery engine at Juneau gold mine Marv J Antique Engine Archives 5 10-20-2002 09:51 AM
Webster Gold doug kimball Paint Shop 1 01-19-2002 11:29 PM
