Wisconsin Engines
Information on a two cylinder Wisconsin
this thread has 5 replies and has been viewed 11912 times
Old 01-14-2009, 12:28:06 AM
ciggs ciggs is offline
Default Information on a two cylinder Wisconsin
I have a lincoln 180SA welder with a 2 cylinder wisconsin
Spec-50048
Size-31/4 x 31/4
Model TF
Serial-2215766
The mag
FM-X1 2B7
X3543596
The question being I read that the TF model came with a 31/4 x 31/2 bore and stroke @ 14 hp running around 2400 rpm and replaced in 1957 with the THD model that had the 31/4 x 31/4 bore and stroke @ 16 hp running around 3600 rpm.
I was thinking it was perhaps a later TF model but the mag places it in 1949 unless its an older mag that was swaped? or was it ordered by lincoln with that size bore and stroke?
or is my information incorrect?
Old 01-14-2009, 01:53:46 AM
jamest jamest is offline
Default Re: Information on a two cylinder Wisconsin
The tf and Thd have the same bore and stroke. Thd is a newer engine. Check this site out - lots of information there on Wisconsins.HTTP://bellsouthpwp.net/z/i/ziradog/tocframe.htm
Old 01-14-2009, 03:45:41 AM
Later, the THD came along, with the same bore & stroke as the TF
TFBore & Stroke
3-1/2 X 3-1/4
14.6 @ 2600
1946
1957
THDBore & Stroke
3-1/4 X 3-1/4
16.8 @ 3600
1957
1976
2-cyl. Replaced TF for more HP. TE Obsoleted.
2033520
January 1, 1953
2232308
January 1, 1954
so its a late 1953, they must have made a mistake with the bore being 31/2
Old 01-14-2009, 07:04:23 PM
Zira Zira is offline
Way back when I was a young man, one guy in my high school class signed up to take typing. We all laughed at (and about) him, until someone observed that he was teh only male in a class with a bunch of attractive girls. It was then that we realized just how smart he was, and how stupid we were.
As I see you all referencing the typos on my web site, I am reminded once again of how stupid it was not to learn to type (now keyboard) when my mind and my fingers were young & flexible.
Yes, it should be 3-1/4 X 3-1/4. I will update it as soon as I can remember where I put theh files (really).
Old 01-14-2009, 11:08:30 PM
alejandro barrera alejandro barrera is offline
Hope this help
Old 01-15-2009, 01:30:51 AM
Yes thank-you for the helpful information. I was trying to figure why they droped the TF model in lue of the THD model
I could possiblity understand perhaps dropping down in bore size to rev the motor an extra 1000 rpm to achieve 2 hp and than wondered what if they speed up the TF model an 1000 rpm to see the hp results were or rev the THD model to 2600 rpm and see what the hp out put would be. Than I wondered if the gears and ratios came into play.
but historic value tells a greater story of economics and engineering.
Later, the THD came along, with the same bore & stroke as the TF but with different bearings and different head/jug design in line with the VH4.
The TF model also shared parts with the 4 cylinder model2-Cyl. L-Head Addition VE4-VF4 Family (same blocks, pistons and rods).
VH4D 3-1/4 X 3-1/4 30.0 @ 2800 1956 4-Cyl., Even-Firing Addition to VE4D and VF4D Family.
1957 THD 3-1/4 X 3-1/4 16.8 @ 3600
kind of handy to have simular parts that interchange between models, cost effective as well.
now I wonder what change occured with the bearning design or materials in the bearnings in 1956 or 1957.
GGB has a long history of leadership in technology, which has laid the foundation for our position today as the world's largest plain bearings manufacturer.
1956 Introduced DU, the first steel-backed bearing material based on PTFE.
PTFE reduces friction, wear and energy consumption of machinery
The redesign of the head/jug design I can see to allow for the
Stellite exhaust valves, the “D” meant stellite exhaust valves
They are hard coated stainless steel exhaust valves, and I mean VERY HARD COATED (mince no words). Anyone who drives a lot of miles or runs an engine hard should want these things, as they are worth every penny of the price.
The engines are reving higher with slight increases in hp probility with more demanding loads as well, where there's load there is heat.
Wisconsin 4 cylinder info? tony i Wisconsin Engines 9 12-20-2008 05:08:39 PM
Wisconsin Information JohnTaylor Antique Gas Engine Discussion 4 11-21-2007 06:33:29 PM
Another Wisconsin 2 Cylinder Genarator Jud Generators & Motors General Discussion 0 03-09-2007 12:57:28 PM
wisconsin inline 4 cylinder n0grv Wisconsin Engines 1 10-13-2006 11:04:14 PM
Wisconsin 1 cylinder help needed, quick....! KidDynamo Wisconsin Engines 5 04-12-2005 05:29:46 PM
