Pneumatic riveting hammer.Hello, We are currently restoring an old engineplow and the frame needs a complete rebuild. I'm...this thread has 9 replies and has been viewed 759 times
Hello,
We are currently restoring an old engineplow and the frame needs a complete rebuild. I'm looking for a pneumatic riveting hammer for rivets 1/2". Does anyone has or knows one for sale with the dies? Transport and payment is no issue. Marc. |
Hi if you don't care what it cost they make rivet hammers in Germany and did in in Uk. I may have some spare rivet snaps. Advise dia of head and shank dia. in case your hammers are not the same as ours. I think for a one off job it may be better to pay someone to do it for you. bob
Hi Bob,
I wouldn't know where to find somebody doing this in Belgium. We also plan to do more restorations in future and like to do it ourselves.. I have a smaller hammer but that only goes to 5/16" rivets. What company in Germany makes them? Marc. |
I have one, complete with dies, but dont know what its worth or how to export it to Belgium.
Roger |
Hello Roger,
Just send me your phone number, and some pictures if possible. I will contact you over the phone than. It can be delivered in the States, that's not a problem. Marc. |
Please send me your E-Mail address, I'll try to get a picture today. My address is: rsteckhan@frontiernet.net
Thanks Roger |
Have you considered using a modern electric hammer drill? Several manufacturers make very substantial units, I suspect Bosch tools are available to you. I don't know if rivet header shanks are available but it shouldn't be too difficult to make or modify a standard shank for that purpose. These drills allow you to select rotate and hammer function or hammer only function. First thought would be to use hammer only, however the rotate/hammer function might actually work better. If you buy a hammer drill you will at least have a handy tool around the shop for the next time you need to do some concrete or stone work.
Joe B |
Are those numbers rivet diameter or length? A boatbuilder I knew used a air chisel with the chisel cut off and the shaft rounded off. Worked real good for copper boat nails used as rivets.
If clearance is not a problem make a big "C" frame on one end dish a rod the size of the head you want then use a hand hydralic pump or porta power on the other end with a dished cup on the ram. works right nice
Hello Terry,
I think the rivet would be to cold before that hand pump would have riveted it. I found a good hammer in Michigan, thanks to one off the members here. Marc. |
| Riveting clutch lining | caf | Antique Gas Engine Discussion | 6 | 07-09-2008 07:24 PM |
| Need info on Chicago Pneumatic diesel engine | country | Vintage Diesel Engines | 2 | 09-22-2005 08:05 AM |
| Riveting | Jess VanWinkle | Stationary Steam & Traction Engines | 5 | 03-10-2004 06:28 PM |
| Central Pneumatic engine info | MICHAEL G. ESCH | Stationary Steam & Traction Engines | 0 | 12-07-2003 11:39 PM |
| CHICAGO PNEUMATIC ENGINE QUESTIONS | David M. Lyon | Antique Engine Archives | 2 | 10-11-2001 09:05 AM |
