Request Info. on an Eclipse EngineI am in possession of an old Eclipse Pump Jack Engine that by all major appearances except one...this thread has 1 replies and has been viewed 278 times
I am in possession of an old Eclipse Pump Jack Engine that by all major appearances except one resembles Harry's Old-Engine #18. The exception is this, while the flywheel with crank handle has the name Fairbanks-Morse cast in it, the cylinder casting only bears the name "ECLIPSE" (no Fairbanks-Morse), with no patent number or date. Cast in small letters on the upper crank housing oposite the flywheel are "VAID" or "VAIO". Could this have been made by the Eclipse Windmill Company before Fairbanks-Morse purchased them? Any help would be appriciated.
The engines without the patent on them are most likely built pre-1914 (which was when the patent was granted and assigned to F-M). The patent was applied for in 1911 which coincides with the start of production. Eclipse windsmills were part of F-M from the 1890s so it well and truly pre-dates the construction of the Eclipse engines.
The V numbers are part numbers. Here is a pic of my engine: Some more pics and info are at: http://www.oldengine.org/members/pml...anksmorse.html |
The Following User Says Thank You to Patrick M Livingstone:
| Simplicity Engine Info Request | FrankZ | Antique Gas Engine Discussion | 0 | 10-24-2008 05:02 PM |
| ONAN 3KW Info Request | morrisjd | Onan Generators | 2 | 12-28-2005 08:04 AM |
| Info request on 15OJC | Sean W | Onan Generators | 12 | 08-31-2005 09:36 AM |
| info request | Derek Watt | Antique Engine Archives | 0 | 04-26-2004 04:45 PM |
| Re: Info Request | don baker | Antique Engine Archives | 0 | 05-13-2000 09:52 PM |
