| Military MEP and Aircraft Gen-Sets MEP Mobile Electric Power, APU Auxiliary Power Unit and other military surplus generators. |
Load meter unstable during runDuring a recent quarterly test run under load, the gauge that indicates the percent load was...this thread has 2 replies and has been viewed 962 times
During a recent quarterly test run under load, the gauge that indicates the percent load was unstable on my MEP003 generator. I had it at about 50% load and it would occassionally drop to 0 for a while, then back up to indicate a load. It did this a number of times. Voltage and frequency remained constant and no interuptions in the house. One thing that may be related is that when I was stowing the genset, I noticed that the battery connections were slightly melted--I hadn't secured them snuggly to the terminals. Do the batts serve a function other than starting the motor and could this be why I had problems with the load values? Or is it simply the gauge is bad? Thanks much for any help.
Steve |
Jiggy,
I see this is a few days old, but have you checked all the wiring between the meter and the transducer? Sounds like a bad/broken connection. If not, more than likely something bad inside the meter making intermittent contact. Replace the meter first and see what you get. eric |
I know nothing about MEP's (don't see many in commercial service), but I did run into this problem recently during a loadbank job on a SimPower. It had fuses in metal holders that had come loose. It was the feed circuts to the meters off the three legs of a three phase unit. The fuses had spead the fuse holders open. A pair of pliers fixed it, just squeezed them tighter. I would bet you will find the problem in a like spot. I have also seen intermittent contacts in the rotary selector switch. Sometimes, contact cleaner and rotating the switch for a few cycles may clean them up.
Mikey |
| Onan12.0DJC-18 12 lead with unstable voltage | ChrisM | Onan Generators | 14 | 07-22-2009 09:50 PM |
| Gunny, need your help! (unstable governor) | Mikey4026 | Onan Generators | 23 | 07-06-2009 11:30 PM |
| cycle meter | Bob S | Onan Generators | 7 | 03-18-2005 08:14 PM |
| Amp meter | Benny Mckheean in NC | Antique Engine Archives | 16 | 11-29-2003 07:34 PM |
| Photo sites unstable | Steve Gerot | Antique Engine Archives | 4 | 12-20-2001 03:42 PM |
