Scintilla magneto,
I have two Scintilla magnetos ( VMN7DF ) fitted to a 7-cylinder Continental W670A Radial Engine. No...
this thread has 7 replies and has been viewed 2497 times
Old 01-23-2009, 10:51 AM
Talltee44 Talltee44 is offline
Exclamation Scintilla magneto,
I have two Scintilla magnetos ( VMN7DF ) fitted to a 7-cylinder Continental W670A Radial Engine. No problem on tick-over(800 rpm). Severe missing from 1200 to 1500 rpm, then perfect up to 2100 rpm. Same situation going up the revs as coming down. Any help would be useful, where do I search next, please ?
Old 01-23-2009, 01:07 PM
ListerDiesel's Avatar
Default Re: Scintilla magneto,
Sounds more like mixture than sparks.
You could also check that you haven't got a worn part that vibrates/oscillates at a certain speed.
Peter
The Following User Says Thank You to ListerDiesel:
Old 01-23-2009, 03:00 PM
K D Redd K D Redd is offline
I am with Peter. I would not think both mags would show the same failure. That is one of the reasons why airchraft engine have dual ignition. Does it run the same when running left mag only, right mag only, and then both?
Kent
Old 01-25-2009, 07:24 AM
Peter, Bonjour.
Thanks for replying, we will check the mixture, but the engine gives full revs without any misfiring. If you are ever in France for holidays, please call by and see us on the airfield in La Baule.
Terry
Old 01-26-2009, 12:59 AM
Exclamation Re: Scintilla magneto,
You might want to check out the condensers - they may be getting tired, especially if they are getting old. Sounds more like a mid-range transition problem with the carb though - pay special attention to the float level, and the fuel ports by the throttle plate. Is your miss a stumble on accelleration or a steady miss? Miss on accelleration is an indication of insulation breakdown in the secondary wiring (spark plug wires).
Old 01-31-2010, 11:53 AM
bbeci85 bbeci85 is offline
Hy!
I have a scintilla magneto,type NAB1 R1K.I like,to know which engine or motorcycle used these type?
Old 01-31-2010, 02:20 PM
Question Re: Scintilla magneto,
Talltee44, have you resolved the engine miss?
The Following User Says Thank You to Andrew Mackey:
Old 07-20-2010, 01:02 PM
Andrew, yes ..... and no !
We bought a new magneto from the States, seemed OK at first then the engine "coughed" a couple of times on base leg. Have since changed the SCINTILLA Condenser, seems OK for the moment, but we find the engine very temperature sensitive. Thanks for your helpfull comments. Talltee44
Bendix Scintilla Magneto chzuck Magnetos, Ignition Coils and Spark Plugs 6 06-27-2011 11:35 PM
IHC H-1 Magneto George Vaughan Magnetos, Ignition Coils and Spark Plugs 4 01-21-2008 09:05 PM
Magneto - which one? ihorse Antique Engine Archives 1 11-06-2004 11:17 PM
FM Magneto what does it fit Larry Hughes ( WA ) Antique Engine Archives 5 03-04-2003 09:54 PM
F-M Magneto Derry Nichols Antique Engine Archives 2 06-01-2001 08:20 AM
